Question about Bosch Dishwashers
Bosch SG145E15Uk time keeps changing in cycle eg 30 min cycle can last for at least an hour if i dont keep an eye on it
ohms
  • 1879 Answers
SOURCE: My Bosch SHU 5315 always
"The repairman said these washers seldom have mechanical failures and the main board failure is the most common failure."
Taken from this link
Posted on Aug 25, 2008
dutchman05
  • 487 Answers
SOURCE: Bosch Dishwasher no longer counts down the cycles, keeps running
UNfortunately that sounds like the controle module and you can not have that fixed. only replacement of the part will fix that problem
HERE you can find the drawing and parts. You can also order them here
Posted on Nov 30, 2008
SOURCE: Tecnik dishwasher keeps on washing... and washing!
the "programer" has gone
Posted on Dec 11, 2008
SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Posted on Oct 10, 2009
  • 3741 Answers
SOURCE: S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
How to use the delay timer on my washing machine
Each time you press it it changes the amount of time before the chosen program will be finished
eg 4hr means in 4 hours the cycle will finish
Sep 27, 2014 | Bosch Washing Machines
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Hi I have a bosch classix maxi been great for the last couple of years but it has failed for the first time yesterday. The dishwasher did not start it just kept making a groaning noise and would not start...
Completely unplug the dishwasher and leave disconnected for at least 10 mins.
Also be sure to check the drain pipe is not kinked or obstructed and that the filter is also clean and empty
May 04, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher does not complete cycle
The problem is the timer/control. I checked for a recall but your model wasn't on the list. Many of these had a recall for the control, they were a fire hazard. Heres a link to help install the timer/control http://appliancehelponline.com/dishwashercontrol.html. When you remove the front panel there will be to plastic hinge covers be sure to reinstall these they help keep it quiet. They just slip over the hinge. The rest of the removal will be the same.
Jun 02, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Dishwashers Logo
57 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
