Question about Acer Aspire 1642ZWLMi Notebook
Acer 1640z boots up fine, but no post screen and bleeps
I flashed the bios with an update from acer, which worked fine (winphlash from phoenix). After restarting it beeps loud, 1 long, 2 short with black screen (no acer welcome and no post) and then boots xp pro fine, everytime.
Dear all,
I also posted this one under "Notebook Bios Problems" which might not be the correct place. Anyway here it is for you to see and maybe you can learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS should I use i.e. how do I know if I need the AT or UMA version - how to verify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started acer 1640z boots up fine, but no post screen and b - icon_sad.gif but later I was all smiles icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED acer 1640z boots up fine, but no post screen and b - icon_lol.gif THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
This worked for me and only cost me £5, Here is the web sit i got it from
http://www.wimsbios.com/phpBB2/topic9512.html
Hope it works for you
Tony Swannell
Posted on Jan 13, 2009
I can't update my Travelmate 8104WLMi. Every time
it is not flashable then you dont ever update your bios unless it has a problem.
Oct 19, 2009 | Acer TravelMate 8104WLMi Notebook
Bios update failed *flash*
Did you make copy of your original bios before flashing...if yes then reflash with your original.
If No then trying reflashing again making sure no power cuts, dont touch computer until flashing is complete.
Are you using the correct bios for your MoBo?
Jul 04, 2009 | Acer Computers & Internet
I want to update motherboard bios. manufacturer : esys current bios : Phoenix-Award bios oem : 945p Release 10/24/2005 V6.00PG
DISCLAIMER: It is NOT recommended that you upgrade your BIOS firmware unless you are a.) experiencing a problem related to your BIOS; or b.) a qualified service technician. Updating BIOS firmware can give you undesired results, not the least of which is the complete malfunction of the computer.
TO WIT:
Phoenix WinPhlash is a Windows-based application for re-programming Flash memory device that contains a PhoenixBIOS with Flash2000™. The utility works with all Windows operating systems and works in: Advanced and User modes. Advanced Mode is for engineers and provides full access to the DMI strings and all WinPhlash options. User Mode is for PC users who need to save or update their platformware safely without corrupting the code or causing system failures. Phlash16 comes with WinPhlash as well as documentation for support technicians, end users, and developers of platformware.
AND:
The next post will have a download link...
May 17, 2009 | Computers & Internet
Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
May 04, 2009 | Acer Aspire 1640Z Notebook
Acer aspire 1640z bios update
That's a memory or RAM error. You need to re-seat the ram of your machine.
Jan 14, 2009 | Acer Aspire 1640Z Notebook
Black Screen After Bios Update ?????????????????????????????
sir bios needs to be formated ,,,,,you need to counsult a hardware tech ,,,they have a flash gun which can format the bios compltly and rebuild it ,,,,as update might have affected the video card so after formating the bios we need to chk to video and graphic card,,,,
Sep 10, 2008 | Acer Aspire 1640Z Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
to BIOS.WHP.
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
Dec 17, 2007 | Acer Aspire 1642ZWLMi Notebook
Acer Aspire 1642ZWLMi Notebook Logo
636 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
