Question about Epson Office Equipment & Supplies
Ink catrige cannot be recognized - Epson Office Equipment & Supplies
    Guru:
  • 571 Answers
Step 1:
Check if your ink is properly plugged inside the cartridge.
Step 2:
Remove and put the cartridge back in. and Check if it works.
Posted on Dec 06, 2012
Toner empty
try to shake the toner after removing it if there is still remaining ink left. If non, replace the toner to its nearest Printer provider outlet
May 11, 2011 | Office Equipment & Supplies
It is notprinting black ink. The ink cartridge is nearly full i have cleaned nozzles, no help.
try another catrige, check if anything stuck in nozzles, use proper catrige, the number of your originle catrige and current should be same,but for sure the problem with either with your catrige or the place where you fix you catrige.
Feb 28, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Ink is not showing up when I print but the cartridges are full
Hello there!
Did you used that catriges before and refilled them now?
IF you done that, somethimes ends of catriges(their holes) can be stucked with jonized colour and they can close the path of your catridge ink to your paper. You need to do regular cleaning, take a bit of alcohol, make it be about 20% alcohol 80% water, put on a little peace of rubber, clean your catridge "lenses" and try again on your Printer.
If this is not working then concider that your catriges maybe are out of ink.
Sincerely
Aleksandar Adzic
Apr 18, 2010 | HP Officejet 6500 Wireless All-in-One...
Printer do not recognise color catrige
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer Ink wont work!
HI~ First Check your ink..if you using compitetor ink or CISS ink , Remove The Rubber that are in the Ink Cattridge there, Coz When the print head **** the ink from catrige with pressure it will stuck the print head from spraying the ink out...  After Remove those rubber that are on the ink catrige you need to clean it to release those presure that build coz of those ink catrige build....                                                   If it dont work your print head need to be purge and you need to get in Maintenance mode...then coz you are using generic ink it maybe have spray to other part of the printer the ink Sensor is very close to ink absorber and the Generic ink usualy leak coz the design are not good but it is cheap and you need to know how to use it...
Dec 18, 2008 | Brother Multi-Function Center MFC-240C...
Printer dont print black
You might not have cleared the clog out enough, you might not be able to fix that issue. Have you tried a Clean and wick?
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Printer won't print
u refill the catrige? if u do this the printer don't work because the catrige has abloody chip that count the ink, and when the ink finish the chip blocks or burns. so try whita brand new catrige.
Oct 18, 2007 | Epson Stylus C66 Inkjet Printer
15 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
