Question about HTC G1
Ring 3 times then goes to Voicemail
My G1 only rings 3 times then goes straight to voicemail. Does anyone know how to change the lenght of time it rings before diverting? I have been through the Call settings and Sound settings. Have I missed something?
Also, I wish T-Mobile would hurry up with the development of the new Bluetooth Application so we can sent Items via Bluetooth.
Many Thanks
  • delonbesson Apr 19, 2009
    I am actually getting fed up. I just can't receive calls anymore
Does the phone actually ring 3 times. I was having the same problem I was informed that it was not even going to my phone. When I had this same problem T_Mobile could not fix the problem using the 3 g network. If you shut off the 3g feature your problem will go away
Posted on Jan 13, 2009
How do I change the setttings in my phone to ring more times before it goes to voicemail?
look it over many have a button that slides to change that or look thru the setup menu.or manual
Jan 26, 2016 | RCA ViSYS 25423RE1 4-Line Telephone, Blue...
My phone rings 3 times and then goes to voicemail. Many times I cannot get there in time and I would like my phone to ring five times before going to voicemail,
Look at your call forwarding or divert settings, change the settings to cancel all diverts or to divert to voicemail only when the phone is off or not answered. Chances are that all calls are currently being diverted to VM
Jan 21, 2015 | Office Equipment & Supplies
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
Phone does not ring goes straight to voicemail
hello, its is possible that you have activated your call DIVERT...
Try to deactive all call DIVERT on your phone device.. Go to your settings, check CALLS SETTINGS, THEN YOU CLICK ON CANCELL ALL DIVERT..
cheers.
May 13, 2010 | Lands Phones
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
Jun 18, 2008 | LG VX8300 Cellular Phone
Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
Phone rings only one time and goes to voicemail
You cannot make the ring longer from the phone. You must call AT&T and have them changed on their side.
Mar 26, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
HTC G1 Logo
825 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
