Question about Kyocera Office Equipment & Supplies
Kyocera MC-3060 Error code c6020 copier - Kyocera Office Equipment & Supplies
SOURCE: SYSTEM ERROR
The Kyocera MK 3050 shows system error. We have turned it off and back on this does not help.
Posted on Nov 12, 2008
  • 126 Answers
SOURCE: error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Posted on Jan 28, 2009
  • 215 Answers
SOURCE: kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
Posted on Mar 30, 2009
  • 83 Answers
SOURCE: How to fix Error code C6020
Order the modified fuser plug connector. There is also a later firmware update to fix this code. This code happened to me on a few selected machines after I did firmware upgrades to add the interrupt button on the touch screen and to speed up the loading time. The thermistor is not guilty!
Posted on Jan 26, 2010
  • 36 Answers
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Posted on Apr 09, 2010
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
Kyocera fs-1118mfp may copier display error code C6020 please help forthe solution
Remove the fuser unit and check if the heater lamp, the thermostat and/or the thermistor are broken
May 11, 2014 | Kyocera FS-1118MFP Laser Printer
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Code c6020 180
That is a fuser error. Replace the fuser & reset the code in service mode. You will also want to update the firmware of the machine.
Dec 13, 2013 | Kyocera KM-1505 Copier
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
Sep 25, 2012 | Kyocera Mita Toner 37085011 for DC-3060 &...
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
Mar 10, 2012 | Kyocera Copystar CS-1820 Black and White...
How to fix code C6020 of kyocera km1820
how to fix error c6020...1st step is go get a gasoline and a match and then pour the gasoline to the kyocera and then lit it with your match stick...it will automatically restart..for more details contact your kyocera supplier.
Nov 04, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
How to solve error c6020 for Kyocera KM-2035 copier? it has stopped
The C6020 is a fuser error code and should be checked out by a Kyocera tech.
May 18, 2010 | Kyocera KM-1505 Copier
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
74 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
