Question about Toys
Tomy Digital Plus Monitor TD350 Digital Baby Monitor has no display or work but recognises charging in the cradle can it be fixed
Pressing the power on off button makes no difference as the display panel still does not display anything and there is no sound. The monitor is left off the cradle in the day time where the charge drops down to 2 or 1 bars through the day. It is left on the cradle overnight to charge up and has done so until now. Is there a problem with the battery or is it likely to be a more serious problem
SOURCE: Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Posted on Jun 19, 2008
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
SOURCE: Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Posted on Jul 06, 2009
  • 154 Answers
SOURCE: I got a new battery for my daughter's power wheel
maybe bad battery or charger not compatible
Posted on Aug 02, 2009
SOURCE: Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Posted on Mar 30, 2010
I lost a connection of tomy digital viedo srv400
Hello. I think I've worked this one out. Turn both on as usual. Go to the main menu screen on the parent unit and click on add camera icon. Then click camera one.... but before clicking the add button, go to the camera itself and click the power button as follows - two short clicks, then hold the power button - the green light will start flashing. Keep holding the power button on the camera and click the add button icon on the parent unit. They should pair. The camera may turn off then, but it should be paired - simply turn it on again. Worked on mine, but took a long time to work out how to fix. Please email if you need any help. hbmb8@bigpond.com
Oct 26, 2014 | Baby Gear
Tomy baby monitor not working
How exactly? Is it powered? Does it have no sound transmitting? Are both transmitter and receiver on the same channel setting? Are they close enough to be useful or too far away from each other that no signal is being received?
Let me know and I'll help further :-)
Oct 14, 2014 | Baby Gear
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
FA error code on screen Tomy Walkabout Platinum monitor
Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
Regards,
M
Feb 21, 2010 | Tomy Freestyle Baby Carrier
Toys Logo
37 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
