Maytag washer lat9406aae won't spin
Machine filled and agitated but now won't spin belt looks good
  • 1294 Answers
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Posted on Jun 05, 2007
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sep 27, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
