Question about Ricoh Aficio 1224C Black and White Copier
I have a ricoh 1224c service code SC 827 appearing at startup.
How can i clear this message?
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
SOURCE: Ricoh Aficio 1224c error code SC 544
Well, I have no idea why changing your password would affect it this way. the code you're experiencing is a fuser warm up error, due to blown fuse, thermostsat, possible power supply prob...regardless, it can only be reset by a service tech in service mode once the problem is fixed. Sorry.
Posted on Mar 05, 2009
M2Tech1
  • 313 Answers
SOURCE: Ricoh 1224c
hI
tHE SC661 is an image processing fault due to time input error I would think if you have changed some settings to print out thge sp sheets (found in the service mode 5.mode at the end of this section you can print out the sheets) or it could be a faulty IPU board. Let me know if you need more info SC619 is not a known error..sorry
Posted on Jul 16, 2010
santosj27
  • 263 Answers
SOURCE: Ricoh 1224c Error SC-421 Please
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Posted on Jul 12, 2011
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
How to decode Ricoh (Aficio) 1224c with code sc 670 from my color copy mactine....
In the service mode (clear modes 107 hold down clear/stop key) then punch in 7807 on the number pad then execute to reset the sc 670, if it doesn't clear you may have a bad controller board or HDD. Hope this helps
Aug 03, 2011 | Office Equipment & Supplies
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1224C-Fusing Oil Almost Empty
Enter SP mode - Clear mode(yellow button);
107 and press and hold Clear/stop key for more than 3 sec.
Enter SP 5-810 and set to 1.
Then switch off and on the machine.
Good luck and please rate me, thanks.
Jan 12, 2009 | Office Equipment & Supplies
Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Jan 09, 2009 | Office Equipment & Supplies
Sc 481 on my ricoh aficio 1224
Jan 08, 2009 | Ricoh Aficio 2015 Copier
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Ricoh Aficio 1224C Black and White Copier Logo
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
