Washer fills then stops
Washer will fill with water and then do nothing. pumped water out and it will refill but then nothing. this washer is about 13 yrs old it will fill up think it might wash then when time to rise are spin sounds like it still washing. cant get the water to go out. my washer is about 20 yrs old
  • 700 Answers
There are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Posted on Jan 12, 2009
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
Already took off pump & cleared out $12 in change but still will not pump all water out or spin out. can hear pump running but think the damage has already been done. would it be pump or pressure...
If the washing machine won't fill up, make sure that the water supply valves are turned on. Next, make sure there are no kinks in the supply hoses that run from the supply valves to the washing machine. If nothing is obstructing the hoses, you may have another controls issue.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or filling too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fills a tube in the pressure switch. When the air pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Read more: Tips to Repair a Washing Machine ' eHow.com http://www.ehow.com/way_5435622_tips-repair-washing-machine.html#ixzz1C6BhALK0
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer filled up with water and then nothing.
It is probably due to the drain pump.You need to take the drain pump out
and make sure that nothing is jamming it,if it is clear and still does this
then drain pump will need to be replaced on the unit.
Apr 06, 2010 | Kenmore 24032\24036 Top Load Washer
Flahes from FL to the temperature (13) after refiling. Temperature level will also not increase.
FL is usually a flow sensor/switch fault. If you have just filled the tub, the pump may not be properly primed. The best thing is to fill the tub through the skimmer when you first start filling it, that ensures the pump is filled with water and is not air locked. You may have to force water into the skimmer to push the air out of the line or loosen a union on the discharge side of the pump to get it primed. FL will not let heater run because it thinks that there is no flow.
Nov 18, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
