Question about Scotts Company Scotts Lawns Edgeguard Deluxe Spreader
I need the setting for scotts turf builder edge guard for 6 lbs per 1000 sq ft
Setting for 6 lbs per 1000 sq ft
2 Suggested Answers
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
What are the settings for 5 lbs. 1000 sq ft on a scott speady green 2000
the low end od the stting bar is for 1/2 pound per thousand sq ft each mark adds 1/2 pound
Sep 24, 2011 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts Company Scotts Lawns  Edgeguard Deluxe Spreader Logo
80 people viewed this question
Top Scotts Company Garden Experts
john h
lnbn1975
Tom Chichester
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
