Question about Panasonic Workio DP-2500E Copier
Copier quality is so bad
I got a dp-2500 series copier and it has done around 100k.
i bought this printer and i been told everything was fine.
but when i try to copy, quality was so bad (dots are not continous... for example if i print a photo there are of white sopts where it should be black!).
i changed the toner and the drum. now the copies are better (text is readable) but photos are not very clear.
can somebody advice me what i should do.
tanks
oo7
  • 2 more comments
  • eupu Jan 12, 2009
    Hi idriss47 ,
    could you kindly let me know how to do a test print. i only tried using copying. never tried printing as well.
    thanks in advance for your tip.
    oo7
  • eupu Jan 16, 2009
    HI,
    I have tested test page and still the page quality as same with a normal phtocopying. so it seems the problem is not with the scanner.
    please help.
    regards
    oo7
  • eupu Jan 18, 2009
    hi,
    ren16, thanks for your reply. the main problem i am having is in my country, panasonic dealer does not provide services for this model. so i somehow managed to find a technicion from that company and did a service. i was present when the guy did the service.
    i think near the drum he showed me a roller ( i think this is called magroller) and said he is unable to clean tat because the black pouder sorrounding one was a magnetic one, and he said we cant by that in my country.
    but according to you, normall toner is in magroller. please let me know is it safe to remove what ever surrounding in this roller.
    (mag roller pic http://www.alibaba.com/showroom/Mag_Roll...)
    please let me know only thing surrounding the magnetic roller is also normal toner, if not do i need to buy something else. because when touch that roller te ouder was moving due to magnetic effect.
    thanks
    oo7
  • Idriss B
    Idriss B May 11, 2010
    can u print its test? if yes ...so tell me how it looks?
  • 100 Answers
Is the printout of pictures erasable?
if yes, the fuser roller is damaged.
if not. . . try this:
most probably the magroller of the process unit is dirty. (some toner hardly stick on it).
to clean the magroller:
1. remove it from the process unit
2. remove the toner using isop alcohol
3. remove the toner(stain) by using metal polish.
4. clean again using isop alcohol to remove the residue of metal polish.
is this helpful enough?
if not pls inform me because the next suspect part is the LSU.
Posted on Jan 18, 2009
    Champion:
  • 320 Answers
You might have the scanner checked!
Posted on Jan 12, 2009
  • STEVE RAYMOND Jan 13, 2009
    you might have to go into the set up or the menu mode, otherwise you may want to go to panasonic.com and check there.!
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
I need an owners manuel for my lexmark 2500 series printer,scanner, and copier model # 4428-001
Hello. Here's a link to the Lexmark website where you can download the User's Guide for you Lexmark 2500 Series printer,scanner, and copier model # 4428-001. Hope this helps.
Mar 25, 2010 | Lexmark C533DN InkJet Printer
WORKiO DP 2500 everything is working properly no image on the drum the machine does not report any error
yep!
For dp-2500 the common and usual problem is light or no image on print
and the common cause is the contact plate between drum and magroller. there must have a proper contact through that plate.
sometimes we also encounter the contact spring(3) of hvps going to process unit - misaligned position.
you may also check the tension spring of the drum (located inside the drum) if it has proper contact to the shaft.
... pls inform me if this still isn't helpful.
Mar 22, 2010 | Panasonic Workio DP-2000P Copier
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
Error E01-22 - Check Printer on my DP-2500
"E1-22" 5th & 6th mirror assy. sensor problemMirrors are out of position, was someone cleaning the mirrors or touched for it for a reason??? if not the sensors are bad
Aug 28, 2008 | Panasonic Workio DP-2500E Copier
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Computer and printer not communicating
unstall it all download drivers from website not use cd ok
Feb 10, 2008 | Lexmark X2500 All-In-One Printer
Panasonic Workio DP-2500E Copier Logo
106 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
