Question about Dell SE198WFP LCD Monitor
Dead Monitor Hi guys I have a Dell lcd monitor SE198WFP 18 months old (out of warranty). The monitor will not power on. I have changed the fuse on the plug, only for it to blow the new fuse. I do not wish to throw away as it seems such a waste. Although I have a multimeter my knowledge of electronics is nil. I imagine there must be a fault in the monitor that is blowing the fuse and would appreciate any guidance you can provide.
  • 1 more comment
  • Anonymous Jan 30, 2009
    I have the same problem as iain-swansto
  • Anonymous Mar 02, 2009
    same with me dell make and sells junk!
  • dick butkuss Mar 07, 2009
    My dell dell se198wfp is 13 months old and the power button wont light and the screen flickers a little. dell makes junk.
  1. gamers
  2. cheats
Posted on Jan 12, 2009
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
Hi: I have a DELL SE198WFP monitor and Dell computer (running Vista). The problem is the picture on the monitor is elongated horizontally, meaning, round things have a "stretched" egg shape...
You need to set yuor PC Video resolution to the native resolution of this monitor for the correct aspect ratio and best picture; it should be 1440x900 @60Hz
http://support.dell.com/support/edocs/monitors/se198wfp/en/setup.htm
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 14, 2011 | Dell SE198WFP LCD Monitor
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
When plugged into power I get no green light at the pwr switch, All is black. Is there a fuse burned out or is the pwr. switch broken???
1. Try a different power cable.
2. Open the monitor up, see that the soldering to the cable connect, or the switch isn't broken.
Jun 22, 2009 | Dell SE198WFP LCD Monitor
Try the troubleshooting procedure here:
Click Here
If that doesn't work, the monitor has most likely failed and will need to be replaced.
Apr 20, 2009 | Dell SE198WFP LCD Monitor
Dell SE198WFP LCD Monitor went blank and will no longer work. Any suggestions
Try the troubleshooting procedure on the Dell website:
Click here
If the monitor still doesn't work, then it has probably failed and will need to be replaced.
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
Dec 29, 2008 | Dell SE198WFP LCD Monitor
Dell SE198WFP LCD Monitor Logo
328 people viewed this question
Alun Cox
