Question about Franke Saphira Espresso & Coffee Maker
Franke flair malfunction 8 - Franke Saphira Espresso & Coffee Maker
    Problem Solver:
  • 17 Answers
You have problems with the brewing group. perhaps the o-ring on the upper piston is broken.
Posted on Jun 21, 2016
3 Suggested Answers
SOURCE: franke saphira malfunction 8 help
We Had The Same Malfunction 8 Problem And It Came Down To A Swolen O-Ring In The Brewing Piston, We Replaced The O-Ring With One Slightly Smaller That Still Sealed The Compartment And Our Problem Was Solved, Hope This Helps Others.
Posted on Feb 19, 2010
Malfunction 8 on the Saphira is a fault in the brewing head region. We have two of these machines, the first time I saw the malfunction 8 message it was a brewing head problem, fairly straightforward to change but I believe they are quite pricey. Worth a strip down and a wash out as they can bind with coffee grounds. The second occasion it turned out to be a problem with the motor that drives the brewing head. It is a fairly small dc motor with a worm drive plastic gear, it has a micro switch mounted on it to measure the movement of the brew head assembly. On this machine the gear had stripped, so the brew head wasn't being moved, and that generated the malfunction 8 code again. Fairly simple to change, but no idea on the price of the part, but unlikely to be cheap. Also it is unlikely that the gear itself can be changed as the motor is held in a plastic assembly which will almost certainly self destruct when opening it no matter how careful you are. Incidentally, both of these machines have done over 50,000 coffees, which is probably way more than they are designed for.
Posted on May 15, 2011
How to remove the lid on a franke flair coffee machine
If you are refering to the main cover! firstly the hoppers have to be removed. then the metal plate on the top(cup warmer) secured with 4 x t15 torx screws. once the plate is removed the main cover is secured with 4 oval headed screws 2 of them located under the plate just removed. the other 2 are located under the adjustment rings for the grinders. the main cover then can be removed. there are 2 electrical connection plugs that have to be disconnected .
Apr 26, 2015 | Franke Flair Espresso Machine with...
It says malfunction 8
its a brewer fault or brew motor.
Feb 24, 2015 | Franke Flair Espresso Machine with...
Why won't my Franke flair machine won't run only says please there a reset switch ?
there is no reset switch, please wait on the display indicates the machine is heating . but the sensors are not registering the temp. this means either the thermoblock/s have failed (unlikely) there are upto 4 thermal fuses mounted on the thermoblocks . this is more likely the problem. any more info required please et me know
Jan 10, 2015 | Franke Flair Espresso Machine with...
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Got a malfunction 4 on a franke flair ? Any ideas
Hi.I think its a temperature measuring fault in the steam circuit. Most likely to be the thermal sensor on the thermoblock. Check to see if the sensor wires are broken or corroded. Can also be the control board. I'll put my money on the thermal sensor. Dazza REPAIRER
Sep 24, 2011 | Coffee Makers & Espresso Machines
How can I get different size lattes and cappucinos with my Franke Flair? all it gives me is a shot size serving...
enter programme button.push and hold for 5 secs.machine will show def product. press programme again to product comes up on the product you want to adjust eg use the + and - buttons to scroll through the espresso setting. if you want to adjust anything in the settings, you need to press programme. then make the adjustment with the + and- buttons then press enter when finished the actual adjustment .once finished with the espresso and happy press exit button.repeat the process for the next button. you can down load a manual at franke .com
Aug 17, 2010 | Franke Saphira Espresso & Coffee Maker
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Franke saphira malfunction 8 help What is this?
Malfunction 8 is mother board failed, you will have to take it to franke uk
Apr 16, 2009 | Franke Saphira Espresso & Coffee Maker
Franke Saphira Espresso & Coffee Maker Logo
1,168 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
