Question about ASUS A7N8X-E Deluxe Motherboard
Looking to buy mother board which will be mainly used for gameing
Need comparison on motherboard which stands in first 3place in respect
to features, performance & cost.
Thank you.
  • 144 Answers
Looking for a guide to buy the best motherboard ,check this website
even this website
you will get an idea,,,,,,,
Posted on Jan 12, 2009
I have problem with my mother board mercury when i download game give me massege that you need grphic 3d to play this game.
You motherboard is not having graphics needed to play the 3D games.
You need to buy a new graphics card.
Thanks for using FixYa.
May 22, 2011 | Mercury P4VM800M7 Motherboard
I have a 20pin power supply adapter that reduceses to a(p8) 6wire&(p9)6wire plug that plugs into the mother board of my system.
A 20-pin ATX main power cable, is converted into two 6-pin AT main power cables, by that adapter.
20-pin ATX main power cable, and it's respective connector,
6-pin AT main power cable, and it's respective connector,
As I'm sure you are aware, the color code of the insulation of those power wires, deems what Voltage they are.
Let's look at charts that compare the older AT main power cable connector, and power wires, to the newer ATX main power cable, and it's power wires,
Scroll towards the bottom of the page, and look at the comparison charts under the heading - Wiring Diagrams
Now if you would, post back in a Comment, as to what the actual problem is.
Aug 01, 2010 | Computers & Internet
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    I have desk top GY 768AA w/serial no..ONH 8020PPB mother board is broken where can i buy a spare
    Desktop computer cases have standard mounting holes and screw stand offs.
    There are a huge range of motherboards available, select well known brands, my favorite are Gigabyte, Intel and MSI.
    Select a motherboard with the features you require. If you are into gaming, graphics/CAD then select a motherboard that does not have a built-in graphics chip, and then you can get a high end graphics card.
    Nov 18, 2009 | HP Computers & Internet
    I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
    If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
    Oct 04, 2009 | Computers & Internet
    Can i put a graphics card for my intel D915GVWB mother board?
    You can not use PCI-EXPRESS graphics cards. Only AGP 2/4X Graphics Cards Supported ( 1.5V Only) You should look for This kind of Graphics cards.
    I recommend , You must try changing your Motherboard with processor and buy a graphics card ( powerful one) to play these games. Otherwise You wont enjoy any of those games you mentioned.
    n.b : a common PCI-E card has 16x speed where you cannot use more than 4x on your system.
    Apr 04, 2009 | Intel D915GVWB Motherboard
    first u know vga of *********** board is built in
    so it take memeory from ur main ram so umust have atleast 1 g ram
    2nd your vga driver is intel so with games which need good vga card will not work
    so my advice u need to buy vga card to play good
    i think geforce 9600 1g is suitable for games as example undercover prostreet fifa 2009
    Jan 03, 2009 | ASUS P5E-VM DO Core 2 Quad Socket 775...
    Lost driver cd
    Simple, look for some kind of reference to model name physically printed on main board, ie "GA-XX1239". Go to gigabyte's site, search via board model number, download audio, video, chipset drivers etc for relevant OS. Normally there's a pic of board so you have a visual comparison.
    Sep 19, 2008 | Intel Motherboard
    Asus mb model numbers
    One of the better vendor sites is where there are a few ways to do something close to what you want. There is a compare feature that allows you to do a side by side comparison of many different boards, feature by feature. The other tool they have is a power search, where you can select the various features you want: type of processor, SATA ports, PATA ports, USB, Firewire, Wi-Fi, Lan, etc. I am not aware of any feature decoder for their designations.
    Sep 06, 2008 | ASUS P5PE-VM Motherboard
    Processor for P5VDC-MX
    Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
    Jan 29, 2008 | ASUS P5VDC-MX Motherboard
    ASUS A7N8X-E Deluxe Motherboard Logo
    258 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
