Question about HP LaserJet 4650 Color Printer
Error control panel 51.21
Al encender termina de calibrar y me marca el error de impresora 51.21
  • 71 Answers
SOURCE: hp office jet 4255 all in one ( error 0xf0af800)
Trata de bajar el nuevo driver directamente de HP e instala tu impresora otra vez. Muchas veces eso resuelve el problema
Posted on Jun 09, 2010
puertobori
  • 7733 Answers
SOURCE: el problema es que la impresora HP j3600 no
Trata este enlace HP Support & Drivers.
Posted on Oct 20, 2010
puertobori
  • 7733 Answers
SOURCE: En el display me muestra el error "Atasco
Trata este link en ingles pero facil de entender.
Posted on Oct 22, 2010
puertobori
  • 7733 Answers
SOURCE: Me marca fallo en el
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Nov 02, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  5. Wait 60 seconds.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
Problemas con bomba de gasolina kia 1995
buena stengo una sportage 94 y le he cambiado tres veces la pila de la bomba marca bosh, le miaramos el rele y esta bien, la presion de la misma y marca 60 libras, no se cual puede ser el fallo, siempre mantengo el tanque a !/4 de combustible, que puede ser la falla? gracias
Feb 07, 2012 | 1995 Kia Sportage
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Que se puede hacer cuando la impresora se cicla al encender y solo marca inicial izando sistema Samsung SCX-6122
tengo el mismo problema amigo, oye cual fue la solucion??? se que la tengo que llevar con un especialista, pero a lo mejor es algo sencillo y pueda repararse y ahorrar unos pesos, me encantaria saber cual fue tu solucion, de ante mano te mando un abrazo, Javier.
Apr 07, 2011 | Samsung SCX-5530FN All-In-One Laser...
Necesito instalar la impresora pero la comutadora no reconose el programa
Hola:
Tu puedes bajar el software directamente del internet, solo tienes que ir al sitio de la marca de tu impresora, por ejemplo si es una HP ve a: www.welcome.hp.com. Y haz click en support and drivers y escoje el modelo de la impresora que compraste. Es todo.
Mar 07, 2011 | HP Computers & Internet
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Tenemos una t160 y en el visor da el siguiente error "32 cartucho no soportado" pero tampoco se puede acceder al menu propio del equipo.¿Cuales serían los pasos a seguir para...
reviza que que sea el cartucho correcto
trata de quitar todos los cartuchos y encenderl a impresora sin los cartruchos instalados
instala los cartuchos de nuevo
si no funciona prueba los mismos pasos pero al encender de nuevo la impresora deja precionado el boton de encendido por 30 sec o mas para hacerle un RESET al sistema
SALUDOS!!!!!
Aug 11, 2010 | Lexmark Optra T610 Laser Printer
La impresora mp 130 yo la apago y cuando vuelvo a encender se va al boton de alarma y luego se quita y aparece el mensaje de put in cartridge y no puedo entrar al menu manual de la impresora
intenta presionando el boton cancel (el triangulo rojo) por 6 segundos, a veces hay que repetir el procedimiento, eso deshabilita el sensor de cantidad de tinta en el cartucho.
Jul 20, 2009 | Canon Office Equipment & Supplies
No puedo inprimir nada
Hola, necesita decirnos el modelo y la marca de su impresora.
Envienos otra pregunta , incluyendo el modelo y marca de su impresora, y la palabra Driver, que sinifica controlador.
Por ejemplo si la impresora es Canon Pixma MP310 , titule la nueva pregunta como : " Driver - Canon Pixma MP310 " recivira un enlace al sitio web de donde descargar el software para su impresora.
Muchas gracias.
Mar 25, 2009 | Canon Office Equipment & Supplies
HP LaserJet 4650 Color Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
