Question about Shop Fox W1711EXT Table Saw
Replace bearings table saw shop fox w 1711 - Shop Fox W1711EXT Table Saw
4 Suggested Answers
  • 152 Answers
SOURCE: I have misplaced my manual for my Fox Shop table
Copy and paste this link in your browser search and the PDF file will download
www.woodstockint.com/images/manuals/W1677_m.pdf
Aduz
Posted on Mar 26, 2009
efs_perpends
  • 1996 Answers
SOURCE: Fox Shop Table Saw won't start
Your saw has a reset button inside the magnetic switch assembly. You may need to pull the cover off to reset it. Unplug the saw first.
Consult the user manual p47 at this link, if you don't have yours handy. http://edge.woodstockint.com/manuals/w1711ext_m.pdf
If that doesn't do it, look to a breaker in your fuse box.
i hope this does the trick. If so, please take a sec to rate this post. Otherwise, let me know what you discover and we'll try to sort it out!
philwalker78
  • 608 Answers
SOURCE: Fox F36-522B table saw: The blade
Hi, there is no lever or knob adjustment as such but if you look underneath where the motor and blade shaft mount in the carrier you can loosen the mounting bolts and twist the carrier in the direction required to align the blade then re tighten them.1 mm out of parallel is only half a mm of twist. Hope this helps, regards Phil.
Posted on Aug 20, 2011
Need bearings for transpower tsc-10hk table saw
IF you take the bearings to a good autoparts store or a bearing supply shop, they can look them up or they can micrometer them and find substitutes. This is a lot more productive then trying to locate a dealer or service center.
Jan 30, 2015 | Saws
Adjust the tighting arm on shop fox fence
You can find the manual here:
http://tinyurl.com/oraxzup
The parts for the rip fence are on page 16.
Oct 20, 2014 | Shop Fox W2006 Classic Fence w/Long Rails...
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Jun 16, 2012 | Shop Fox W1752 Mini Wood Lathe
My new 1677 won't run, just hums. Shop Fox tech support seems clueless. Say that running saw on a 5000 watt generator invalidates warranty even though manual never mentions problem with using generator....
I am with you on the start capacitator. I would look at the model and make of the motor and give mgf. a call see if they have one.
You do need the amps there to start these saws. Make sure it matches what your generator is putting out.
Please let me know what you find.
Feb 11, 2010 | Shop Fox W1711EXT Table Saw
Failed electric motor on 10" Craftsman Table Saw
by seized is it burnt up or are the bearings just bad, the bearings are minimal but the field/armature would be more. Give me the model number and I will try and find a breakdown and let me know what we are looking for and I will try and help.
Sep 28, 2009 | Craftsman 10" Table Saw
New or used motor for a Craftsman 10" table saw
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
Apr 26, 2009 | Craftsman 10" Table Saw
Mar 26, 2009 | Shop Fox W1711EXT Table Saw
I have misplaced my manual for my Fox Shop table saw. Is there somewhere on line where I can read one.
Aduz
Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Sep 12, 2008 | Dewalt Saws
Shop Fox W1711EXT Table Saw Logo
Top Shop Fox Saws Experts
Tom Chichester
ray gallant
Are you a Shop Fox Saw Expert? Answer questions, earn points and help others
