Question about Whirlpool Washing Machines
Whirlpool LSR5232LQO wont spin or drain
The washer starts up fills up and aggitates but wont do anything after that
fixinit4me
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
http://www.repairclinic.com/0088_11_1.asp
Posted on Oct 28, 2007
aborcass
  • 2651 Answers
SOURCE: Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Posted on Jan 21, 2009
  • 686 Answers
SOURCE: Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Posted on Apr 06, 2009
SOURCE: Washer fills and drains but won't aggitate or spin
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Posted on Apr 10, 2009
jsrock516
  • 5911 Answers
SOURCE: My washer will fill and aggitate but will not
If the washer fills, begins the wash cycle, then stops at the spin cycle and won't drain, then you need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jun 12, 2010
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Washing Machines
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
