Question about HP Photosmart 7510 e-All-in-One - multifunction printer / copier / scanner color
HP PHOTOSMART 7510 ALL-IN-ONE PRINTER - Message shows carriage jam.
Message shows carriage jam. I have checked and there is no paper jamming. I did have a paper jam which I removed but a lot of ink had drained out of the cartridge and may have dried in the bottom. I have gone through all of the steps in the HP center. The printer was purchased 1/26/12 and their website says it is out of warranty as of 8/31/12! Any suggestions? Message shows "Carriage jam - the print carriage cannot move".
Cops
  • 64 Answers
SOURCE: paper jam message
it is most likely to be the smalest of pieces of paper stuck on/in/around a paper sonsor flag. the best way to get rid of it is either to try blowing through the paper path yourself or to get a can of compressed air and use that to save on light headedness.
Hope this helps, if not dont hessitate to contact.
Pete
Complete Office Printer Support
Pete@wedotoners.com
Posted on Oct 11, 2007
SOURCE: error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
SOURCE: Printer shows Carriage Jam, but I can't find it.
Push cartri9age to left about a 1/4", with finger pressure. Un-jammed my printer.
Posted on Apr 06, 2008
checkitright
  • 1362 Answers
SOURCE: my printer says carriage
the carriage is the part that holds the ink. It is probably stuck in one place, either the top of one of the inks is open or something is in the way.
Posted on Sep 11, 2008
Scott Ellin
  • 558 Answers
SOURCE: My Hp officejet 4255 all
Hi There,
Thanks for you using FixYa.
The problem can be solved by repairing Motor/Roller.
It needs to have a shaft at both ends (dual shaft), and it takes some soldering and replacement of the black round plastic gizmo with tiny fingers around it back onto the shaft of the replacement motor as well as the tiny worm gear and the little green circuit board (has to be soldered onto the new motor).
You can order it cheaply at www.allelectronics.com and specify the above motor model but be sure to select the dual shaft one.
Regards
Ellin
Ell
Posted on Sep 26, 2008
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
My printer jammed
Open the front cover and check the carriage.Look for pieces of paper or something else inside the printer.
Sep 29, 2009 | HP Photosmart C4280 All-in-One InkJet...
We had a paper jam in our HP Photosmart C5280 Al-in-One printer. Error message in window reads: Carriage jam! Open door, clear carriage jam, and then pres OK to continue We opened door and even...
after closing the cover and removing the jammed papaer does it still says "paper or carriage jam"????
if it still prompts you that theres a jam and you've already removed it, try to turn off the printer, disconnect from its connections (pc and ivr or ups or wherever its connected) wait for like 5-10 sec then connect it again...
hope this resolves ur prob...
ive experience it to with my hp j3500 all in one... a paper jam, this is what i did and i think it worked for me... hope it do to your printer.. ciao!
Sep 10, 2009 | HP Photosmart C5280 Printer
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
Hp officejet all-in-one 6210
printer jerking and message says carriage jam and everything is clear, but paper goes in sideways.
Oct 13, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart 7510 e-All-in-One - multifunction  printer / copier / scanner   color Logo
136 people viewed this question
Seeker5211
Seeker5211
