Question about Kenmore 47722 / 47724 / 47729 Electric Double Oven
Model number 79048873900 kenmore double wall oven, self clean wont work on bottom oven
The top self clean works, and everything else works on the oven when you hit the self clean button a second time to clean bottom oven it doesn't do anything. No option for time or to attempt to lock, almost as if it doesn't sense a bottom oven, but does cook in the bottom oven. Thanks for any help
Amigaman
  • 248 Answers
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Posted on Nov 04, 2007
SOURCE: Kenmore oven locked after celf cleaning
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
Posted on Aug 31, 2008
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Kenmore 47722 / 47724 / 47729 Electric Double Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
