Question about Exercise & Fitness
My freemotion 730 treadmill won't respond when I press "start" on the console (all the lights are on and everything).
Freemotion 730 I have only been using it for six weeks!
bwinton
  • 83 Answers
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Posted on Apr 29, 2010
taran_2005
  • 10515 Answers
SOURCE: Pro-Form 680 LT treadmill console
You could disconnect the treadmill for few minutes,say 15 minutes and then turn it ON. If the problem persist, this is an indication of hardware failure. I have no idea whether you would be comfortable in testing electrical components and replacing it?
However, would give you some pointers . The NO display and NOT respond option is suggestive of one or combination of reasons :-
1. There is a loose connection. You need to inspect all wires running from control board to the console.
2. Hardware failure such as control board, transformer, fuse or even power tube.
If you have the instruments and would like to carry repair, revert and i would be able to provide you with few pointers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
ercupa190
  • 12223 Answers
SOURCE: I have two cardio zone
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Posted on Sep 13, 2011
ercupa190
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
Freemotion 730 treadmill drive motor not working,
Failed motor, failed control board, could be either or both.
Jan 23, 2017 | FreeMotion Exercise & Fitness
Freemotion XTE Elliptical display won't turn on at all
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
God bless youc719c602-5572-4506-9d14-437751e71106.gifc3db8187-db09-41b3-90bb-d7e9652e1ebf.gif
Jun 04, 2013 | FreeMotion Fitness xte Elliptical Trainer
Horizon treadmill won't incline
Step 1:
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
I received my new controller for my freemotion 790. How do I remove the old one?
1) you must did receive some instruction for to replace the old ones by new ones.
2) you can contact to the company that they send the installation sheet for to proceed with the adjust
Please do it, is very important. They have special instruction for to replace it.
God bless you
Jan 22, 2013 | FreeMotion 790 Interactive Treadmill...
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
Jul 27, 2012 | Exercise & Fitness
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
Incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
Apr 06, 2010 | Icon Exercise & Fitness
Exercise & Fitness Logo
287 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
