My Lg47LK520 HDTV picture and sound started blinking tonite. I had noticed a couple wks. ago that occasionally it would quickly blink only maybe once a day. I can watch it on reg. cable and that does
I haven't had the tv a yr. will be in Jan. Always a good pic. no other problems until tonight.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It should have come with a 1 year warranty---if under warranty don't wait too long to get it in for repair.
Posted on Dec 06, 2012
ensapp
  • 30 Answers
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
Bad caps in the power supply. Replace all bad cap or replace Power Supply Module. If you choose to try and fix it yourself yourself will need a ESR Meter to check the caps in circuit. Let me know if this helps.
Posted on Oct 16, 2008
  • 225 Answers
SOURCE: T.V won't turn back on
Sounds like a component shorted out for sure. I will guess he will say, "It needs a new power board". I would guess a transistor or microchip burnt out. Probably ESD damage from a new factory worker.
Posted on Nov 14, 2008
SOURCE: hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Posted on Feb 10, 2009
SOURCE: TV blinks and then no picture at all
HOW DO YOU CHANGE A LAMP BULD IN A SONY HDTV. MODEL#KDF-E60A20
Posted on Oct 11, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
Z130 speakers keep blinking
Sounds like you have it in tuning mode & or pairing mode, provide me with some more info and i can help out
Oct 30, 2017 | Logitech Z130
Hello, I have a Sony KDS-55A2000 and it works fine for a couple of minutes and then it switches off and the green led starts blinking for about a minute and then the picture comes back and works fine
First thought would be the lamp may be about to fail if it has not been replaced in a long time---a warning will be the picture is a bit darker than before and takes longer to get bright than it once did.
Apr 17, 2012 | Sony KDS55A2000 55" HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
When turning on in morning can't get out of menu mode. Once it warms up for about 15 minutes it works fine, but starting to blink into menu mode more frequently. In the morning you can click menue on the...
Possibly could be the remote, the only way to find out is to pull the batteries out and leave them out for a while to see if it does it will the batts are out of the remote
Dec 09, 2010 | Philips 42PFL5332D 42 in. LCD Television
Picture blinks in and out every few seconds
The lines in the picture and the blinking makes me think maybe the digital / logic board is going bad.. you will need a tech to resolve this and it will be expensive.. In time you will loss the picture altogether as the board will get worse.
Jul 06, 2008 | Vizio L32 32 in. LCD HDTV
No Picture/Sound
You have some bad caps in power supply going out
Dec 22, 2007 | Sony KP-53HS30 53" Rear Projection...
Picture turns off still have sound
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then? - Sarah
Jul 30, 2007 | RCA HD50LPW175 50" HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
