Question about Braun MULTIMAG SlideScan 4000
Slide magazine won't move forward on my multimag slidescan 4000, where can get it repaired in Canada
A slide got jammed and broke a part which I had replaced (ordered part from germany...) but photo repair shop which did repair doesn't feel comfortable working on this issue.
3 Suggested Answers
  • 38 Answers
SOURCE: I am trying to install my Braun multimag slide
Driver available here http://www.latestdriversupdate.com/driver/36681.html
Posted on May 30, 2010
drm130146
I had a used SlideScan 4000 that I tinkered with trying to get working for 2 years with several computers, drivers from the web & firmware updates. It would scan a few slides then freeze. It seemed to depend on the memory, as I could scan 2-3 slides on low resolution before freezing, but stopped half way through the first slide on high resolution. I finally found that I had to go into Device Manager (I'm on Windows 7 - Ultimate) and delete all other imaging devices (well I think I was able to leave the computer's web cam on) to enable the device driver to load properly. I installed Cyberview X - which installs the driver but I am using Vuescan for my slides. I recall my dad having a similar problem getting another scanner to work on his computer. Apparently it is a common problem to have conflicts with scanner drivers if you have more than one on your computer.
Posted on Jan 07, 2016
Where can I get Braun MULTIMAG SlideScan 4000 repaired?
this is from the Braun site in Nuernberg, Deutschland:
HP Marketing Corp.
Tel.: 001-973-80 89 010
P.O. Box 715
Fax: 001-973-80 89 004
Pine Brook, N.J.07058
Email: info@hpmarketingcorp.com
Feb 10, 2013 | Braun MULTIMAG SlideScan 4000
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
My nailer won't put out nails some of the time and when it dose it's 2 at one time and some of the time won't put out at all untill i thump the push bar.
could be a few areas to look at. First does the driver retract fully after firing a nail, if not then I would replace the piston o ring. Do the nails move freely in the magazine, if not the magazine could be bent or possibly you have a problem with the nail collation, they have to slide freely and I think both areas need looked at. If you need more assistance I would need the brand and model number so I can help better.
Jan 03, 2012 | Air Tools & Compressors
I have 2003 Toyota Camry and the power seat is jammed all the way forward and won't move back. The tilt and lumbar power all works fine. Any idea whta may need to be replaced and how much for...
I'm sure you might have thought of this, but double check to see if something is jammed under the seat keeping it from moving back and forth. Move the set up as high as it will go, and look with a flashlight especially at the tracks. As to repairing it, you are going to pay time and materials for repairs at a body shop, and if the motor is burned out, that is going to run around $100 to $130 unless you attempt to locate one in a junkyard (nto likely since it is still a fairly newer vehicle). Removing and installing the new motor will require removing the seat, so I wouldn't be surprised if the total was $250-$300 or more. If it were mine, I'd carefully check the connections to the motor, the harness, and the seat tracks for obstructions.
Jul 07, 2011 | 2003 Toyota Camry
I bought a used Elmo TRV-35H 35mm projector. The camera works fine, but the tray only moves in reverse when I press the forward or reverse button. And after moving through a few slides it then moves...
Remember, mains voltages exist within the projector and thus the unit MUST be disconnected from the supply line whilst carrying out any servicing.
The reported fault sounds like sluggish operation of the advance/reverse mechanism. Lubricants used in the past tend to age and dry out so that the mechanism doesn't function correctly. IF YOU ARE CONFIDENT TO DO SO, remove the top of the unit and locate the slide mechanism. Carefully clean with cotton buds dipped in pure electronic cleaner and then re lubricate, using an oil dripper with the finest industrial sewing machine oil - emphasis is on a 'drip' of oil on the moving pivot points. Put the top back on and try again.
Problems with remote controllers are suually associated with tarnished contacts either in the hand unit or the projector. Once again, the contacts can be carefully cleaned and all should be well once more.
If you are using Kodak Carousel magazines, make sure you are using the correct magazine for your slides - cardboard or glass mounts. Don't mix slides in a magazine, as this can also cause problems.
Dec 13, 2010 | Elmo Projectors TRV-35H Slide Projector
My Braun 3650 is scanning everything RED, I changed computers and is still scanning red, any idea why it's doing that?
See previous fix for black lines problem is likely the same i.e fractures in the flexible cable between the scanning head and mother board, changing this cable will likely cure this fault.
Oct 05, 2009 | Braun MULTIMAG SlideScan 4000
Mac can't find the driver for the Multimag 4000 - using cyberview
Hi
lets start with what mac system you have there? the device is supported on Mac: OS X 10.1.5 or higher
Dec 26, 2008 | Braun MULTIMAG SlideScan 4000
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Braun MULTIMAG SlideScan 4000 Logo
18 people viewed this question
Top Braun Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
