Question about Garden
Where can I get a replacement DRIVE BELT for a Honda fg314 tiller?
2 Suggested Answers
SOURCE: Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
Posted on Mar 31, 2010
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
Model FG314 - where can I obtain a replacement belt?
Go to one of those outfits that specialize in mower, tractor, outdoor equipment repairs and they will have the belt.
Mar 14, 2016 | Honda Garden
I have a f22o honda rotor tiller.it runs great but when i put the unit in dirt it won't spin.it will if it's not touching anything.
You probably have a belt drive that has is not tight enough to pull under a load. The belt is pulled by an idler pulley that engages when you start the tines. Check the belts by working you engage lever and look for the belt and idler. More than likely there is an adjustment that will allow you to put more tension on the belt thus making it till. Do not do this when the machine is running! The belt should not have flex in it when engaged. It may a little effort to engage the tines when you get it tight enough to till.
Col. Dana Gillespie
May 04, 2015 | Honda Tiller - F220
Replace belt lowes 211-406-062 tiller
Search for a belt routing diagram, I've had the same problem, thought I was going crazy
May 10, 2012 | Garden
Need belt diagram for Troy bilt Pony. The drive belt just broke and I need to 1, buy one and 2, replace.
hi im having trouble on my troy belt riding mower it is a 42 inch im tring to change the belt we have it on but it not right please help me
May 15, 2010 | Troy-Bilt Pony Garden Tiller
Rotertiller drive belt
For these applications it is best to use a factory belt. However the belt is 1/2" wide 59" long.
May 21, 2009 | Garden
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
