I have a sony vaio a230, and the cpu fan is not working at all, is that okay? the system performance is good, and evreything works fine. Thank you,
    President:
  • 1,073 Answers
No its not good, sooner or later your cpu will burn up. It may be working and you may not notice anything but the cpu is getting overheated.
I sugest you get that fan replaced AS SOON AS POSSIBLE.
Good luck to you
Posted on Jan 12, 2009
Is there a quieter fan for the sony pcg-k45?
If your fan is very loud, and works all the time, then probably you'll need to clean up your laptop from the inside. On average it only takes 3 months for any laptop to gather enough dirt so the CPU heatsing gets totally clogged and this causes the fan to work all the time, and in extreme cases your laptop even turns off so it protects the CPU from the excess heat.
Here's a very good overheating laptop cleanup tutorial with some best practices that any laptop owner should know.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Jan 30, 2011 | Sony VAIO K45 Notebook
Hi my sony vaio the fan is always making a lud noise
This is very simple issue. Hope you might read my blogs on the same issue. Basically the CPU fan runs fast only when the processor sends signals to the bios saying "Hey bios iam getting heated, cool me up". The bios initiates a process called as SMM (system management mode) which will lower the data traffic through the processor and takes the control of system with an increased fan speed. This is just for the sake of keeping the processor at the ruled temperature so that it doesnt get fried. But this is a process, even though continuous, will not make the fan go running all time like nuts.
If that is happening to your sony vaio pc, i would suggest you to go ahead, download the latest bios flash, and upgrade the Bios. When the Bios has an issue it triggers the smm mode as if it got signal from processor and it keeps the fan running. So check for the status of BIOS by updating it with a flash program and this will be clear. Good Luck.
Dec 17, 2010 | Sony VAIO VGN-CR220E/P Notebook
Sony Vaio VGN-S5VP/B Noisy CPU Fan
Buy a can of compressed air, a can of fine mechanisms oil, take the bottom cover off the laptop (only a Phillips screwdriver is needed) and clean and oil the fan.
Aug 19, 2010 | Sony CPU FAN CPU Fan
My new cpu can't start
I think there was some hardware issue in your CPU,if RAM is unplg or loose in that condition CPU will be not working,Replug the RAM properly and start the system if still cpu not working thats mean there was a problem with your cpu SMPS fan (place backside in cpu for cooling),cpu fan SMPS is not support,Please change it.
good luck..
Please rate me....
Thanks
Mar 25, 2010 | Sony VAIO PCV-W600G PC Desktop
My sony is over heating
This is almost certainly a hardware fault - the fan will need to be replaced. This is a job you can do yourself if you are comfortable disassembling the laptop. Otherwise I suggest to take it to a repair centre.
Mar 04, 2010 | Sony CPU FAN CPU Fan
Sony vgn-nr120e stops working
Uninstall unnecessary softwares from add/remove programs. Did you noticed that cpu fan is working? If not then clean the cpu exhaust system with blower and also check the cpu fan function in BIOS. When using laptop always use flat surface to place it, mattress or sofa create problem with cooling and exhaust system of the cpu fan.
Hope this will help you.
Regards;
Hasan
Dec 30, 2009 | Sony VAIO VGN-NR120E/S Notebook
Sony Vaio VGN-SZ460N - freezes on System Recovery
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
Jul 14, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Sony Vaio PCG-K30 laptop does not work
By removing the heatsink and cleaning it, you may have wipe d the heat sink compund, or the heatsink is not well attached to the base and is not making full contact with the CPU.
Check for this two conditions, and correct them.
Everything should be fine.
Jun 10, 2009 | Sony (B99860307) for VAIO PCG-K series...
CPU coolers
TYPE YOU'R MODEL # INTO GOOGLE,SHOULD GIVE YOU A GOOD STARTING POINT.
Nov 06, 2008 | Sony VAIO VGC-RB50 PC Desktop
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Sep 21, 2007 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
