Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
I need a replacement ac adapter for my 320g external hard drive 2 of the pins have broken off model no.WD3200EO35-00 cannot seem to find where to get one Thanking You Kaye Bridger
  • 155isalive Feb 21, 2009
    Ac Adapter no longer powers my Elements WD 320 Hard Drive
    I need a replacement.
    Does anyone know where I can get one of these in Australia
    kieran.hooper@ap.averydennison.com
  • Michael Fisher
    Michael Fisher May 11, 2010
    It Says This Unit Is Powered Via Usb So What Do You Need A Usb Cable?
3 Suggested Answers
mbase213
  • 728 Answers
SOURCE: Did I just fry my WD External?
I've done something similiar and I know the feeling, but the good news is that you may not of done the damage you think. Here's what I suggest. Go to this link. Where they will explain the differences of the meanings of the flashing lights. There are so many variables, that it would be to difficult to figure out unless I was actually working on the disk itself. But the page is very easy to understand, and hopefully you'll find what I did, was all I need to do was to power down and up again.
Good Luck!
Mark
Posted on Jan 04, 2009
  • 61 Answers
SOURCE: Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Posted on Feb 22, 2010
Testimonial: "Thank you very much. That's eactly what I was looking for. I appreciate you speedy response."
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
My toshiba 1 Tb automatic backup portable drive won't power up
First you will need to check the AC adapter if there is DC power available. Use a DC voltmeter and put the black lead on the outer ring and red lead on the center pin of the connector that plugs into the external drive, Plug the AC adapter in the wall and see if you have voltage on the meter. Should be roughly 12 VDC. If you do not have voltage then the circuit board inside the external case is failed, if no voltage then replace the AC adapter. As a last resort out can disassemble the case and use the hard drive as an internal one.
Jun 03, 2014 | Computers & Internet
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
I don't know which power adapter to use and I can't locate my user manual. What is the DC input? My problkem is I need to make sure I provide the right DC input - I have several adapters - what is the...
Most externals are 12v input voltage so as long as you have a adapter with this input voltage your be fine, and the hard drive should operate.
Let me know if you need more information.
Thanks
Jason
Oct 15, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The 5v power pin on the AC adapter of my SmartDisk Crossfire external hard drive has been broken. How do I get a replacement AC Adapter?
Take your SmartDisk to any computer-store.
They can open the case, remove the disk-drive,
and mount the disk-drive in a new "empty" external casing,
with a new power-supply.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
for a sample of various "empty" cases, for about $30.
Oct 06, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
346 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
