Question about Honeywell 3800g Wired Handheld Barcode Scanner
Honeywell adaptus 3800g barcode scanner will not read barcodes but still beeps. what should i do??
4 Suggested Answers
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
  • 378 Answers
SOURCE: What software can I purchase
Microsoft Excel can print bar-code labels. I did this for my office for our stock room and they work with every bar-code reader I've used so far.
Posted on Apr 22, 2011
prashant2012
  • 1127 Answers
SOURCE: My 3800g barcode scanner puts
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
Posted on May 26, 2011
Testimonial: "Works! Thanks so much. "
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Need installasion instructions as well as program
Hi
Click hear to find the manual read the manual and install the your HoneyWell 3800G
Jun 08, 2011 | Honeywell (formerly Hand Held ProductsHHP)...
My 3800g barcode scanner puts a prefix of ~% before the UPC number. I'm sure the answer is somewhere in the 156 page manual, but to a non-technical guy like me the manual may as well be written in...
Hi
May 26, 2011 | Honeywell 3800g Barcode Scanner PN...
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
HHP 4600 DOES NOT READ MICROPDF417, BUT READS ALL OTHER CODES. WHY?
The scanner may need to be programmed in order to read the barcodes. If you download the Honeywell userguide for the handheld you can locate that barcodes required to program this for reading these.
May 15, 2009 | HHP 4600 Handheld Barcode Scanner
Honeywell 3800g Wired Handheld Barcode Scanner Logo
110 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
