Question about Honeywell Programmable Thermostat Heater
Can't stop the programming and just put it on one temp help!!!
  • 700 Answers
Have you tried to put it on continued unoccupied? i also think that your can clear the start and stop times on the unit. http://customer.honeywell.com/techlit/pdf/PackedLit/69-2210ES.pdf
Posted on Jan 12, 2009
Amd sempron 140 processor 2.70 ghz
Follow these steps hopefully it will help you
1:-Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.
2:- Remove unused programs
3:-Install and run antispyware software
4:-Free up wasted space with Disk Cleanup tool
5:-Defragment your hard disk drive
If this didn't help you then simply get the Intel software partner Reginout to optimize your system and internet
Thanks
Jun 18, 2013 | Video Game Consoles & Games
Why is computer slow fungsation any time hang
Do you mean slow function ? .a computer hangs when you do not have enough memory (RAM) installed and to many program.
Jun 05, 2013 | Computers & Internet
Compaq presdio slow desktop windows xp
Follow these steps to fix computer freezes problem::
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
  • Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click OK.
ALSO
Delete Temporary Internet Files:
Repeat the steps with c:\windows\temp
After you're done with both temp folders, restart the computer.
Services:
Click Start, type services.msc in the Search box. Press ENTER. Right click and stop each service which is not necessary for you.
For an instant fix use Intel Software Partner Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 13, 2012 | Compaq Presario 5000 PC Desktop
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
My computer say that symantec framework has stopped working and the disk drawer keeps opening and closing. help please
Need to reinstall Norton program manually
1. remove the Norton program with Norton removal tool (www.norotn.com/nrt)
2. clear temp and prefetch ( to clear temp type %temp% in run and to clear prefetch type prefetch in run and delete all files)
3. restart the system
4. clear all the Norton files from registry
5. clear Norton or symantec folder from application data
6. install Norton program
If you get the same issue after we reinstall manually you need to create one administrator account and install Norton program
Feb 07, 2010 | Symantec Norton AntiVirus 2004 - (Open...
I set the tstat manualy for 77 and when we wake up it reads83 what? thanks
You have a pre-programmed thermostat. You'll need to put in settings for each program setting in order to have the thermostat provide you with the heating/cooling temperatures you want at each time period of the day and for each day of the week (in the case of a 7 day programmable model.
Whenever you put in a manual temperature setting, it is only a temporary setting that will get reset at the next pre-programmed temp setting, unless you set the "HOLD TEMP" setting and select the number of days you want it to hold the temp you manually set on the T-stat.
If you can provide the model number, I can help you further with the programming of your T-stat.
Hope this helps and best regards!
Thanks.
Aug 05, 2009 | Honeywell Programmable Thermostat Heater
Nashuatec sp1000 - fuser temp. err.
The fusor errors must be erased entering to service program mode pressing total clear, 1 0 7 and “clear stop for more of 3 sec” later put off and on the copier. But must to indicate that code display, in order to be able to help him. Probably some piece was not placed well, or it was damaged when mounting it.
May 19, 2009 | Ricoh Aficio 1085 Laser Printer
Takes so long to download the programs and never get there.
If you are using Windows XP or Vista here are a few steps that should help. * perform "Disk Cleanup" * empty temp folders(temp,%temp%,prefetch) * delete internet History, Cache, Cookies * empty "Start-up" folder * clean up Desktop * empty "Recycle" bin  * make sure your system has all the latest updates * make sure your have at least 1gb ram * defrag system (after all garbage had been removed) and... * check your internet speed at http://www.speedtest.net as this will affect how fast you can stream video (it is possible that Youtube is playing faster than your system can download the content)
there are other things that can be done but, they should be performed by a service pro. such as...streamline Registry and turn off unnecessary processes.
Feb 03, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
I have a trane thermostat and I need help programming it
If indeed the program is stopping it you can find out by putting the thermostat temp on a manual hold. Set tstat to a desired temperature then push hold. If all works well then you will need to reset your program to fill your needs
Oct 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Unwanted songs added to play list
You might want to try these suggestions: 1. In folders options, click on the box that will show all hidden files. 2. Be sure to copy the MP3 songs unto a Temp folder that you create only for these MP3's 3. Stop all background running programs, like spyware, anti-virus, firewalls etc. Be sure you are not connected to the Internet (DSL). 4. After all of the above has been accomplished, go ahead and do a Copy and Paste of your MP3 from that newly created Temp folder to your iLo MP3 player. I hope this helps. Restart your computer to get all background running programs running again.
Dec 27, 2006 | iLO MP3 Player
Heating & Cooling Logo
37 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
