Question about HP PhotoSmart 7760 InkJet Printer
My hp 7180 printer has a cartridge alignment failure - how to fix
The magenta color seems to be leaking all of a sudden..this all started after a paper jam - now it only prints blue/green all cartidges are full, it keeps telling me there is a cartidge alignmet failure. is there a way to fix it or is the printer jsut junk now?
titik
SOURCE: K60xi won"t align cartridges
what are going to do is just fix thee color ink cartridge of your printer......
Posted on Jan 26, 2008
  • 97 Answers
SOURCE: print cartridge is stalled
If you are still getting error code for "paper jam", remove rear cover and locate the swich in the mid section of the roller mech. It is a little flat piece of plastic that drops in the way of the paper but is pushed away when the paer is fed through it. It might be jammed in the up position telling the i/o timer ther is a jam. With a small jewlers screwriver, push the switch lever back and forth till it is free.
Posted on Jun 11, 2007
SOURCE: Hp photosmart C6180 black cartridge not printing
I found the same thing today. Talked to HP and they offered an upgrade for $250 saying that there was a hardware problem and could not fix it. This is not right. What is HP playing at..
Posted on Nov 14, 2008
SOURCE: HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
Posted on Jul 25, 2009
seeker5211
  • 1089 Answers
SOURCE: Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Posted on May 18, 2010
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Alignment off on HP CP4005dn Color Printer
dear friend
how much life pending in image transfer belt
check first
Mar 27, 2014 | HP Color LaserJet CP4005dn Network Printer
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking ...you should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
Ican't align print cartridges .I change the color cartridge (57) and now when i start the printer i receive a message "Press OK to print Allign page" . The printer start the operation and...
Your color cartridge does n't print well
in order to have a success alignement
check if the expire date has pass
you need to replace the color cartridge or refill it
by this easy method
Jan 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
I have recently bought HP 2025dn, Magenta cartridge is not aligned. I am printing on 90gsm normal paper... help!!
If you are referring to a CPR (color plane registration) problem, where the magenta color plane is not aligned with the other color planes, you might first try forcing a color calibration. This can be done through the control panel menus by selecting System Setup-
Sep 21, 2010 | HP Laserjet Cp2025n Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
7310 won't print magenta
Either you are out of magenta ink or your cartridge is dirty. Just because you've run a cleaning job doesn't mean the printer will fix the problem. The best thing to do is take your cartridge out and use a paper towel to gently clean the head (where the ink comes out). Once you wipe away the gunk you should still get the three colors on each pass of the paper towel over the head. If you only get two colors (yellow and cyan) then your magenta is empty or dried out (happens with ink cartridges used past their expiration date). The only thing you can do then is get a new in cartridge.
Nov 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Oct 07, 2007 | HP Color LaserJet 2600n Printer
HP PhotoSmart 7760 InkJet Printer Logo
Seeker5211
Seeker5211
