Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Fixing a Bosch WFM 3030 washing machine timer
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: remove wfm 3200 pump
Hello, welcome to FixYa.
I understand you are having trouble removing/locating the filter access cover on your Bosch Nexxt washer, correct ?
I've posted my solution to error code E13 which should in turn explain to you how this covered should be removed...the first 3 steps should explain/illustrate how this is done, you can omit the rest if you like or review for cleaning procedure.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to EXTREMELY sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine as you know (about 6" in diameter, lower rightcorner)
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free...it will not rotate unless the release tab is pushed in. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Oct 25, 2011
Hi. I have a problem with my washing machine bosch wfm 4030 ... working but bowel not moving . No spin
Spinning won't help Eat more greens you need fibre surprised you could even type query
Jul 09, 2017 | Bosch Washing Machines
Bosch classixx 6 washing machine drum isnt spinning and the timer is reading
Reasons that can cause this situation are
1- the drum motor is faulty
2- the drum motor relay doesn't receive power
3- The relay receives power, but relay contacts are won out hence not connecting.
There is a wire disconnected that links the motor to the timer board.
Jul 17, 2016 | Bosch Washing Machines
How to operate a Bosch WFM 2000 washing machine
Anon, could not find WFM 2000, go to the link below or Google search your make and model# manual.
Download instruction manuals
Apr 29, 2016 | Bosch Washing Machines
Bosch WFM 3030. Why the belt falling?
was it noisy in spin. the bearing need to be changed
Jun 26, 2014 | Bosch Washing Machines
Bosch wfm 2010 user manual
Hi ,
I am looking for a user manual, for my w/machine BOSCH model WFM2010/08
Jan 13, 2013 | Washing Machines
Bosch Nexxt 500 series washer program cycle selector knob just spins and no longer clicks in place to select a cycle. How do I fix this?
This is a failure of the program controller timer unit and it must be replaced as the locking mechanism or the stepper motor link had failed.
Aug 03, 2012 | Bosch Washing Machines
Timer and door switch for bosch washing machine V428
www.spares2go.co.uk/browse-BOSCH-Spares-m113.htm
www.spares2go.co.uk/browse-BOSCH-Washing_Machine-spares-m113-t713.htm
www.espares.co.uk/search/washing-machines/p/1085
There you go.
Apr 02, 2010 | Washing Machines
Bosch axxis washer fills door locks then nothing no agitate or spin it dose drain when the control is set to spin
The timer/controller is faulty.
Replacement is the only fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
132 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
