Error HSYNC in Konica Minlota 1490 MFP,what does it mean and how do resolve the problem?
2 Suggested Answers
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
When turn on the machine the error code c-c170 indicates
NVRAM and or MFP Board failure. Recommended you get a qualified Konica Minolta Tech out to correct. as The Firmware for the machine may need to be re-flashed. The firmware is at a secured website, for Konica Minolta Technicians. The board might also be bad. the NVRAM is memory that stores major info on the copier. The code is telling you not enough memory for the MFP board or that the MFP board is having issues. MFP are not cheap$$$$$$$$$$$$$$$$$$$.
Jun 11, 2015 | Konica Minolta Bizhub c203 Copier
Konica minlota c 252 clour print problems
Then run the gradation test and registration test
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
C-FB7A ERROR CODE
Sir/Mam,
Recommended you have a technician come out to re flash the copier operating system (NOT printer driver). But the software that runs the copier, It is located at a secure web site at Konica Minlota, any firmware is access able to dealerships and KMBS only..They like to protect there copier Operating Systems..
Feb 07, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta error code c-fb7a
Once again, Sir/Mam,
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Error code c-fb58
Hi Wazza,
CFB58 relates to an internal bus error on the MFP control board. To reset you simply turn the machine on/off (main swithc inside front door) If the fault reoccurs, you may need an engineer to flash your firmware/replace the MFP control board.
If it's the latter, I suspect it will be more cost effective to replace the machine. Average cost of a MFP board for your model is £1200.00
Hope this helps
Regards
Taminol
Apr 17, 2009 | Konica Minolta bizhub C250 All-In-One...
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
Xerox 3100 mfp error code (HSYNC)
xerox phaser 3100 mfp error HSYNC
What can i do to solve ?
Nov 24, 2008 | Office Equipment & Supplies
Want to sell
State exact problem, what happens? what lights/error, where, how often and what you have tried to fix.!!!!!
Nov 10, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
53 people viewed this question
jasbo
jasbo
