Question about Sony CDX-L280 CD Player
Theres no play button!?
I know this sounds simple... but how do i get it to play a cd. i insert it. then it waits a couple minutes then ejects it. by the way it came with the car when we bought our car so we have no manual. the radio is fine, just cant make it play. any advice would be appreciated!
  • 156 Answers
It should start playing automatically when you insert the CD; if it doesn't, then the CD player is defective.
Posted on Jun 09, 2007
How do I play a cd on the radio
Press the eject button and insert a CD. Press the CD mode button and press Play. Usually, when you insert a CD, it will start playing automatically.
Jan 25, 2016 | Cars & Trucks
CD deck
That means that there is a mechanical error concerning the tray gears
Oct 11, 2008 | JVC UX-S57 CD Shelf System
Cd in02 lincoln ls light comes on ( cd error ) wont work or eject ??
This can be from a couple things that caused this. Most the time and 99% of the time that causes this is the cd driver is dirty, which some times it just spits it out after error message comes on. AND in your case, it is staying in there spinning and reading error, and won't eject. One way that is possible to have this kick out is, to unhook battery, wait 5 minutes, and re- hook battery up, and sometimes it will trigger it to eject. If not, you do not want to start forcing something in there, it could cause more damage. You would then, i suggest , take it to car stereo shop as they have all kinds of methods to check it out and eject cd and figure out the fix method. Which could be as simple as a good cleaning, or cd itself was bad, or mechanism is screwed up.
I hope this helps Mike.
Oct 23, 2011 | 2002 Lincoln LS
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
Unit is not resetting
try disconnecting your battery and wait for a couple of minutes, then reconnect the battery. hopefully this helps
Feb 23, 2010 | JVC KD-S890 CD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Can't get a CD to eject on my '05 RAM 1500 RBK Radio
We have tried several of the solutions offered. (i.e. holding eject button down several seconds and then pressing again; inserting another CD into slot 1.5 " and using eject button at same time; pulling the fuse on the radio and waiting 10 minutes w/o using key in ignition and then reinstalling fuse. NONE of these worked. There's a certain amount of satisfaction to "fixing" a problem on one's own, BUT nothing we read about and tried worked. Since we bought the 2005 RAM just last week, we're going to take the problem back to the Dealer to fix. THANKS.
Mar 23, 2009 | 2005 Dodge Ram 1500
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Not reading any cd format
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software
1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
OR
2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
any probs just mail back and ill help as much as i can
Oct 21, 2008 | Philips WACS700 Shelf System
Cd won't eject
sounds like the c.d. has a paper label on it, yes? my stereo won't eject c.d.'s with paper labels,....reach in there with a pair of thin needle nose plyers and yank it out,.....good luck, cracklin joe,......
Jan 19, 2008 | Alpine CDE-7856 CD Player
Sony CDX-L280 CD Player Logo
89 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
