Maytag pav1000aww stopped working
My maytag washer stopped working during cycle, and started making a humming noise and smells like something burning ?
  • 716 Answers
Sounds Like Your Belt Broke And Seized The Motor.
Posted on Jan 12, 2009
Washer wont run but is trying to
check the motor for that, there may be smoething stuck ther. for the humming sound, when did this started happening? for the smell, check for frounded wire. for repeating each cycle, try to check for the housing if its still operational because the burnt smell and the cycle repeating is linked.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Mah2400aww
The problem is the washer is defective.
Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag PAV1000AWW washing Machine
Your machine has a two speed motor. If the motor hums as it tries to spin in the normal cycle, it could be the motor. If there is no noise, it could be a timer related issue.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
