Question about Denon RC-1117
Code for direct tv box
Can i make my denon remote work my sat box ????
  • 6 Answers
SOURCE: Speaker crackle
HDMI is a High Definition Multimedia Interface and has the capability to transmit both AUDIO and VIDEO all in one cable. Your setup right now is transmitting 2 audio frequecys (L/R stereo RCA and HDMI) into the Denon inputs. Not necessary! I would recommend eliminating the red/white audio cable from the direct tv box to the Denon.
After doing such, your receiver should be able to process audio/video signals appropriately. REMEMBER to unplug all POWER CORDS before reconnecting any speaker/audio/video cable, as it may cause a small electrical surge and fry a micro component in your system!
Posted on Feb 17, 2009
  • 119 Answers
SOURCE: speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Posted on Feb 25, 2009
  • 119 Answers
SOURCE: Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Posted on Feb 26, 2009
SOURCE: No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Posted on Apr 15, 2009
SOURCE: Need Denon AVR2500 code for
The remote code I used on my comcast motorola remote to control the Denon AVR 2500 I have is 1360 - worked like a charm
Posted on Oct 28, 2009
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
Cannot get our jumbo remote to operate our satellite receiver which is a Direct TV. Tried all 17 codes.
Unfortunately, this model does not have a learning function, so if it doesn't know the code for a newer product, it cannot be taught. I recommend trying the auto-search function for both CABLE and SAT to see if it can control your Direct TV box.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 10, 2009 | Innovage Jumbo Remote Control
I need codes to program direct tv satelite
Direct TV codes are not provided with the Innovage Jumbo Remote, but it is possible the codes for another box will work. I recommend using the auto-search function for both CABLE and SAT.
I hope that helps.
I need the directions on how to set it up.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Repeat the process with the CBL/SAT button to program for your sat box.
Hope that helps.
Oct 20, 2009 | One For All URC-3021 Remote Control
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Need Denon AVR2500 code for Direct T.V. rc64 remote
Sep 15, 2008 | Denon Audio Players & Recorders
Why doesnt it work?
Try www.remotecodelist.com or contact Jumbo directly and
check with Direct TV.........T.
Dec 29, 2007 | RCA Universal Remote Control
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
Denon RC-1117 Logo
15 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
