Beko wm61675 failing to spin hums spins for two seconds then cuts out
Cleaned out filter to no effect
  • 96 Answers
SOURCE: beko 520w wasing machine
Humming sound at start usually means a door lock problem. Check that the door is actually locking.
Posted on Mar 10, 2008
  • 1294 Answers
SOURCE: beko wahshing macnine wont spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 11, 2008
  • 3 Answers
SOURCE: Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Posted on May 10, 2009
Karthik316
  • 187 Answers
SOURCE: beko wma 510w will not spin
HI,
Try These
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion........
Posted on Jul 23, 2009
  • 1417 Answers
SOURCE: Machine won't drain or spin, Power hums then cuts
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Challenging Instructions And Things You'll Need:
  • Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
please rate this if this help?.
Thanks for using fixya.
Posted on Dec 13, 2010
Small water leak from under the washing machine
not un common for manufacturers to test every 5th , 3rd , 10 th machine if yours came with a defective/ cut/ or otherwise failed pump to drain hose or tub to pump hose. my 15 years in the business hint noisy in spin points at unseated main tub seal/bearing call for factory service don't void warranty by fiddling with it your self ( maybe an easy fix slipped hose,maybe a 3 hr repair for a qualified journeyman appliance technician.
Oct 24, 2016 | Beko Washing Machines
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
My beko wm7247w wont spin
Hi Tina if your beko wm7247w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 26, 2013 | Washing Machines
Beko not draining and spinning
check lid switch, you can pull switch out and hook the wires together and tape them! if it works then youve found the problem. also check the drive coupler, it may be broke which goes from motor to transmission. if its broke, it will not spin. just let me know the outcome ok ! also the clutch, if its humming and it will not work. check the motor out.
Apr 20, 2012 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
