Question about DeLonghi DL48P6 Dual Fuel (Electric and Gas) Kitchen Range
Delonghi range dsc90dffsd oven not warming up
Has been working fine suddenly stopped working no heat in oven, hob and grill are fine
gandhiforyou
  • 275 Answers
SOURCE: DELONGHI GAS RANGE DEGESC24SS COOLING FAN COMES ON NEVER SHUTS OFF
http://www.delonghi.com/ go to this website and select the country you belong to . in there you will find customer services. they will provide you contact number to call. hope this will sort out your problem.
Posted on Jun 25, 2008
  • 1462 Answers
SOURCE: electric grill element on delonghi
check continuity thro the grill element. if ok, then suspect selector switch. there is a overheat cut-out but this would affect the oven element as well
Posted on Aug 05, 2008
SOURCE: I have a Delonghi DFS901ss
yes it is no problem just replace one wire at a time to make sure there go in the same place
Posted on Sep 15, 2008
SOURCE: DeLonghi DFS 090 SO DUAL
I had the same problem,it was something to do with the oven knob switch ,i got an engineer out to fix mine or else just buy a new knob hope this helps
Posted on Mar 25, 2009
SOURCE: delonghi px906 oven symbols have come off
hi there just purchased a delonghi px906 cooker and all the markings for cooker settings are not on there, so not quite sure what to put it on to cook, i don't suppose you know what they are do you?? please could you let knjow if you do many thanx :)
Posted on Apr 02, 2010
Hobs all working oven not working
Hob stopped working, oven still fine on electric cooker, any ideas ...
forums.moneysavingexpert.com/showthread.p...
MoneySavingExpert.comDec 25, 2010 - From this point, we'll assume that you are happy to receive all .... have a "problem" that covers the hob not working but the oven doing so. Gas Hob Ignition Not Working!
May 22, 2007
Oven not heating - Please help
Oct 14, 2006
Oven won't get hot - help please
Aug 24, 2006
More results from forums.moneysavingexpert.com
How to Diagnose a Fault With an Electric Hob ' eSpares
www.espares.co.uk > Advice Centre
Jan 01, 2016 | Logik LFTC60W12 White 60 cm Electric...
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
C362e fan oven stopped heating up fan still works top oven, grill and hob still work.. Had same problem about a year ago, but suddenly started working again before i could get help.... ???
If fan is working o/k, then it is more than likely that the oven element is causing the prob, I would fit a new one under the circumstances.
Please rate my solution.
Thanks.
Jul 14, 2009 | Ovens
Electric grill element on delonghi dfs 903.1 proffessional oven stopped working. Oven element works fine. Is the a cut out switch? nigel
Aug 05, 2008 | DeLonghi Kitchen Ranges
Our Delonghi DFS090S0 oven has stopped heating up. The fan is still working but no temperature.
My grill is not working no heat, hot air is running normally. what may be the reason that my grill heater could be blown, if so, how to replace it?
Mar 30, 2008 | Kitchen Ranges
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
DeLonghi DL48P6 Dual Fuel (Electric and Gas) Kitchen Range Logo
21 people viewed this question
Top DeLonghi Kitchen Ranges Experts
Paul Bade
Dan Webster
Dan Webster
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
