Question about KitchenAid KSM150PSGR 325 Watts Stand Mixer
KitchenAid blender KSB5BU stopped working - humming
This is my friends blender. She said one day it just stopped working. Checked it out and it just hums. Nothing inside moving at all. Asked friend if she smelled any smoke and she said no. Opened blender and inspected motor brushes and the brushes and commutator look perfect. Checked inline fuse as well. Motor spindle turns freely and easily. BTW, turned spindle while unit was on. Zero resistance. Any ideas?
  • KitchenAid Master
  • 1,248 Answers
Is the blade in the working bowl free turning?
Posted on Dec 25, 2013
freetek
  • 5568 Answers
SOURCE: my kitchenaid professional mixer does
It's doubtful that the switch is at fault but either the field or the armature winding could be open. These are fairly easy to check once the innards are accessible, with any multimeter and a little understanding/experience.
I don't know how speed selection and regulation is done in that mixer but it may be electronic (as opposed to earlier electromechanical governors) and checking that section requires a little bit of knowledge about the components used.
When you replaced the brushes, did you notice anything about the surface they contact? The segments are made of copper and should appear shiny where the brushes contact, not discolored or burned-appearing. If they show signs of heat or charring, this could mean that the field windings are damaged.
Posted on Oct 10, 2008
  • 44 Answers
SOURCE: mixer won't start
your problem sounds like the thermister is burnt out.
Posted on Dec 10, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Posted on Apr 04, 2009
ricardok45
  • 135 Answers
SOURCE: Humming kitchenaid
Hi. You have internal damage to the transmission caused by the jamming of the beater. Go to mendingshed.com and download their free Kitchenaid Repair Manual. This covers your K45SS Model. Go to kitchenaid.com , click on customer care, then select search for manuals. Enter your k45ss in this manner k45sswh. Download the parts list. You are now "Armed and Dangerous"!
Unplug the mixer! Follow the instructions in the manual for disassembly. This Manual is worth it's weight in gold.
Get yourself lots of paper toweling and a pair of disposable gloves. This is a greasy project. The trick is to clean off each successive piece removed from the trans, inspect it for damage, and lay each piece in sequence on a piece of cardboard to make reassembly easier, or take a digital photo of every piece as you remove it. Modern technology makes so many repairs now possible due to the immediate photo documentation we can get. Priceless!
Finally, I recommend replacement grease, Chevron FM ALC EP-2 Food Grade grease. Non-toxic!
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 17, 2009
hslincoln
  • 235 Answers
SOURCE: kitchenaid 625 watt 6 quart mixer. Was using it
HAMILTONCOOL - It appears that your mixer had a mechanical failure in the transmission box or planetary gear assembly of your mixer failure - one of the main gears has failed, hence the loss of power to the agitator. You didn't mention any associated noise prior to the loss of power to your agitator, but I'm assuming there was just a little more noise than usual, prior to failure.
The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
Posted on Nov 19, 2009
Why doesn't it start?
Did you fit the brushes back properly, they are keyed on one corner and only go in one way. Check all the wires for continuity with a meter. Check the field windings for continuity as well. Make sure the switch contacts are touching in the on position. You need to track the power then (with your meter) and find out where it stops.
Nov 23, 2015 | KitchenAid Artisan Series 5 qt. Stand...
The paddle on my kitchenaid won't turn. It just makes a humming noise. Any suggestions?
Is the humming noise the sound of the motor straining to turn without moving (it won't last very long like that) or the sound of the motor turning but not operating the paddle?
Dec 21, 2014 | KitchenAid Food Mixers
No power on kitchenaid mixer
Apart from checking a fuse, there is little more you can do. Did you notice a loss of power or burning smell the last time you used this? What make and model you have may help others identify a known problem with your machine.
Kind Regards, Dan.
Sep 08, 2014 | KitchenAid Classic Stand Mixer
My Kitchenaid '09 12C has light on, but no action. All parts click into place appropriately. No reset on base.
If nothing is working then it is your control switch. Pretty easy to replace and get. Cant remember the site name but if you put in your Kitchenaid model name and serial number it will pull up the site for replacement parts.
Aug 11, 2014 | Food Mixers
Donde puedo comprar repuesto de licuadora KitchenAid 9704230 coupling code 112401 en Miami
http://www.amazon.com/KitchenAid-9704230-Blender-Coupling/dp/B000V6ZEZ4
Jun 22, 2014 | KitchenAid Food Mixers
Tipped over my blender, broke the black plastic piece that raises and lowers the top, and now it is stuck in lower position. Won't move.
Blender? This is a form about Kitchenaid mixers . . . assuming that's what you have,and it is a stand type mixer, look at this page:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
And you will see the linkage which was bent/broken. Hopefully you will be able to either straighten the bent part or replace it if it is broken.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid mixer stopped working in mid-use. No warning and now it won't work at all--checked plug and electrical connection and that is fine
Mixer has a power control board inside the domed end cap. If it has failed then you this would cause these symptons.
Mar 13, 2010 | KitchenAid Food Mixers
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Dome and blade assembly for kitcenaid ksb5bu blender
Your exact model number for your cobalt blue artisan mixer is KSM150PSBU1. the dome and blade assembly must be a attachment part. and i will need a better description before i can narrow down what it could be.Hope this helps
Thanks
Sep 11, 2009 | KitchenAid KSM150PSGR 325 Watts Stand...
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PSGR 325 Watts Stand Mixer Logo
181 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
