Question about Sony Audio Players & Recorders
My walkman of NWZ-B172 always display the "VERBINDEN M.USB" when i connected it to computer with USB cable,then how to fix it?
5 Suggested Answers
SOURCE: Sony Walkman NWZ-A826 will not conect to laptop via usb cable
I experienced exactly the same problem on my laptop (Vista Home Premium) after upgrading to NIS 2009.
From Control Panel, I went to Device Manager. Under Portable Devices there was a yellow exclamation mark aginst my walkman (Micosoft Code 19 error). I read around a bit before deciding to click Uninstall. Once that was complete, I clicked on Scan for hardware changes, and hey presto my walkman was recognised again.
This is almost certainly connected with NIS 2009 installation as my walkman was recognised by another laptop (XP) which is NIS 2009-free.
Posted on Jun 11, 2009
  • 65 Answers
SOURCE: Sony Walkman NWZ-E436F will not connect to PC or
First reset yours by the Back button;
If not solved;
Reset again by the button, the On the Computer by Fat32 Format, and then Copy the Initial Files that were on your MD when you Bought;
Good luck
Posted on Nov 04, 2009
SOURCE: sony walkman nwz-e344 freezes when
I had a similar problem with my Sony NWZ-818 today and simply pressed the reset button with a pin to reboot the player (little hole on the side) and it worked!
Posted on Aug 21, 2010
SOURCE: sony walkman nwz-a816 getting usb device not recognized
okay, try plugging it in. Go to Startmenu, right click 'My computer', and select properties. Go to the 'Hardware' tab, then Device manager. Down at the bottom, you should see a section of the tree that can be expanded, entitled 'Universal Serial Bus Controllers' Find the Unknown device part. Select that, then go to 'Action','Uninstall'. After un-installation, the computer might restart. Unplug your walkman. When windows is back up, plug it in, and see if that works. if not, I have an alternative solution
Posted on Sep 09, 2010
NWZ-B105F - unit is fully charged per the display. I go to power on the player and nothing. I've tried he reset button and still nothing. Any suggestions? Thanks,
Make sure that HOLD function isn't on.
Connect it to the computer and reset it again, leaving it connected.
Check the Sony Support Web site to see if there are any available firmware updates for your model.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
2GB Walkman MP3 Player
Feb 01, 2014 | Sony Walkman NWZ-B105F MP3 Player
Walkman NWZ-B173F VERBINDEN M. PROBLEM HOW DO I FIX IT PLEASE
my walkman gives sound of music good but when singer's sing's it is not clear..
Jun 11, 2013 | Sony NWZ-B173F - MP3 Digital player -...
Sony walkman nwz-b172f verbinden M. USB
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Nov 28, 2012 | Sony Audio Players & Recorders
Where can i get a charger for my player (NWZ-E435F Digital media Player Sony corp. S/N: 5083578
The NWZ-E435F Walkman Player can be recharged by connecting it to the running Computer USB port using the supplied USB Cable.The Battery icon will get displayed and indicates the icon during charging.
However, you can try using the AC-U501AD USB charging adapter for charging the Walkman player.
Thanks for using FixYa.
Mar 02, 2011 | Sony Walkman NWZ-E435F Digital Media...
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
When i conneted my player with computer then i
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 27, 2010 | Sony Walkman NWZ-B142 MP3 Player
How do i make my mp3 connect with my computer
I had the same problem. I had not had any problems for months and suddenly it wouldn't connect. I got on live chat w/ Sony (3 times) and finally got someone who seemed to know what they were doing. I have a Sony computer and they had to send me a link for a USB "patch". After downloading it, it fixed it.
Jun 02, 2009 | Sony Walkman NWZ-S616F MP3 Player
Mp3 will not connect with my computer
I had the same problem. Don't buy a new cord. There is a sony place in winnipeg you can get it fixed there.
May 30, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony nwz-S515
Try adjust the USB cable and/or switch which USB port it's connected to on your computer. Also just patiently let the player sit and try not to perform any other actions on the computer. When mine did this, I opened Media Player, wiggled the USB cable and waited. Eventually it connected and worked correctly.
Sep 28, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
3,229 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
