Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Ariens zoom 1844 with intek 18hp Briggs&stratton spraying oil out of the dipstick tube and shut off
Engine started blowing oil out of the dipstick tube and then shut off. Got it started again, after sitting awhile, and shortly after it did the same thing but I could not start it since. It also barely turns over now. I checked the engine breather tube and it was not blocked. What could cause this?
SOURCE: My briggs & stratton will not start
i had a similar problem on a 20 hp v twin. there was trash in the fuel shut-off solenoid screwed in the bottom of the float bowl stopping fuel. It will come out without pulling the whole carb apart.
Posted on May 28, 2009
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 634 Answers
SOURCE: Having problem starting and keeping engine
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Posted on Jul 09, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
18hp v twin brigs when it runs oil comes out of carb
you will see a tube coming from engine block to carb, pull it loose at carb just under the air intake or right behind breather filter. start engine and if oil blows out then its a blown head gasket.
Jun 21, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Running poorly with oily plugs
broke oil rings from moisture getting in one cyclinder
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
