Question about Fossil Negative Display Watch
How to set time in fossil s arck 1121
How i can change the time in this watch..
5 Suggested Answers
  • 8 Answers
SOURCE: Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Posted on Mar 03, 2009
escapement
  • 2334 Answers
SOURCE: Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Posted on Mar 15, 2009
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
I need a manual for a Philippe S+arck PH- 1087 watch.
Google (fossil)(PH1087)(manual) without parens.
May 25, 2014 | Fossil Watches
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
Feb 08, 2010 | Fossil Fuel Josh JR9120 Watch
NEED TO RESET THE TIME, NOT SURE HOW TO DO THIS
Go to www.fossil.com and go to customer care. Once there go to watch manuals and look for your watch.
Apr 06, 2009 | Fossil AU4003 Wristwatch
How to change the time on fossil watch, put the time one hour fwd
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Mar 24, 2009 | Fossil BG2076 Watch
Need manual and battery info for Fossil S+ARCK PH-1002 watch
Of course, you can.
Open the watch and take the battery out. Memorize all the writings on battery and buy exactly the same one. You need to memorize wich way up the battery is originally fitted. If you will insert the new battery the other side up, you can damage your watch movement.
Rate me, please.
Mar 21, 2009 | Watches
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
I can't set the time on my fossil DQ1170 watch. I Can't find my owners manual or an available online manual.
The watch keeps 2 different times. Make sure you are in T1 (look at lower left corner). If it's in T2, change to T1 by holding C button. To change time, hold B button until the watch is flashing. Press A button to go through different settings. Use C and D button to change values.
Apr 27, 2008 | Fossil Watches
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Fossil Negative Display  Watch Logo
609 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
