Question about Kitchen Ranges
Kenmore electric range model 790.96002601 6 inch element dosent work
6 inch element dsent work
SOURCE: manual for kenmore electric range
I finally found a website where I could order the manual.
Thank you.
Posted on May 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
MNTECH
  • 1543 Answers
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Posted on Nov 08, 2008
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Posted on Apr 09, 2009
jsrock516
  • 5911 Answers
SOURCE: Front right (6IN) radiant element went bad
Congrats on your troubleshooting efforts. The element you speak of is called a "dual element". Unfortunately, you can only purchase it as an entire assembly. This is a fairly simple repair that you should be able to perform yourself. Just follow these steps:
First, please review your Warranty Information. Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
I would recommend you have someone assist as this should be a two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with elements turned off.
3. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, you can unplug the entire top panel and move it to flat surface to work on it.
If not, you will have to prop the top panel up.
NOTE: If moving the cooktop to another work surface, place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
4. Remove the defective surface element by disconnecting the terminal plug wires. Make sure you label them.
5. Next, locate the two tabs that hold the element in place. Take note of the numbers that the tabs are inserted into. These are alignment marks and you will need to install the new element in the same manner. Take a pair of pliers and slightly bend these tabs by turning them so you can remove the element. NOTE: You may have to remove the bracket guard that holds the element in place. If so, leave the bracket face down when you remove the screws. This leaves the existing good element from being moved around and reduces the risk of damaging it. Lift the bracket up slightly,and slide the defective element out.
6. Remove the old element and discard. Install the new element making sure you handle with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. NOTE: Ensure you use the same alignment marks.
7. With the element installed, lock the tabs in place and install the wire connectors. Reinstall the screws on the bracket guard.
8. Lower the cook top back into place and secure with screws.
If you have questions along the way, please let me know. I hope this helps you.
PS You may experience a bit of smoking when you turn on the new element for the first time. This is normal.
Posted on Jun 29, 2009
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
How can I fix my kenmore range model#c96863589-1 the oven only will not heat up what could be wrong. is it elements
Possible element faulty or switch unless you have a multimeter and a good working knowledge of electricity be very careful. Remove the two connections on the element and set the multimeter to diode testing or resistance and test across the element if you get a zero reading the element has blown, if you get a positive reading look at the switch.
Apr 25, 2014 | Kenmore 96422 / 96424 / 96429 Electric...
The "element on' light on my Kenmore Electric Range wont turn off.
The element on indicator is typically controlled by the infinite switch (the temperature control) for the element.
Jan 01, 2014 | Kenmore 96412 / 96414 / 96419 Electric...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
On a sears kenmore electric range 790, my mom accidently held the time of day display off by pressing the clock button and holding for more that 15 seconds. (page 13-bottom, if you have a manual). She...
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
Oct 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have kenmore electric stove. the two large element dosen't work
try the controlls or switching the elements with the other buners.
Jul 08, 2010 | Kenmore 99123 Electric Kitchen Range
Kitchen Ranges Logo
62 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
