Question about Maytag 24 in. MDB5651A Built-in Dishwasher
SINK NOT DRAINING
MY SINK IS NOT DRAINING AND ITS NOT THROUGH OUT THE HOLE HOUSE SO ITS NOT TIME FOR THE ROOTER GUYS TO COME
    Scholar:
  • 89 Answers
Could be just the trap. try a simple plunger. gather some water in the sink and plunge the drain. if that doesn't work you might need to take the trap off. unless you are mechanic savvy i dont personaly recomend doing this. other wise its time to call the plumber. sorry. your last bet is to try a pipe snake. i found mine at an estate sale. im thinking any plumbing store should have one. just be carefull not to bust the trap.
Posted on Jan 12, 2009
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
For some reason I can't seems to concent to the wifi in my house.
Try rooter factory reset and conect witout password then reconfigurate rooter setings.
Feb 13, 2014 | Computers & Internet
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
My dishwasher is draining into my sink and filling it up.
House drain must be plugged, other wise water would be going down the drain.
May 19, 2011 | Dishwashers
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
Bosch Front Load not draining
Sounds like a blockage. First port of call. Check where the drain hose goes into the sink trap of your Laundry Trough. Here in Australia we connect the drain hose into the sink trap. Most of the time if the hole drilled into the sink trap is not large enough it can create an obstruction in the waterflow out of the machine. Lint and stuff can build up and partially and at times fully block the exit into the trap. Try this first.
If that appears fine you should remove the drain in the front bottom of the machine. Use a bath towel to absorb the wter that exits as you unscrew the round plug in the bootom of the machine. If the plug wont unscrew or only partially unscrews you will need to call a technician to remove the drain pump and unblock things.
Goodluck. Let me know how it goes.
Regards Sam
May 25, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Jul 12, 2008 | Kenmore 46462 Front Load Washer
Maytag 24 in. MDB5651A Built-in Dishwasher Logo
245 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
