Question about Lexmark C544dn Laser Printer
I am seeing Pink shadowing on print out
Their is a pink coloring primarily around perimeter of paper but is also visible across whole sheet
MUKHTAR
  • 2017 Answers
SOURCE: Color print lines
try to replace with colour catridge bye
Posted on Sep 24, 2007
olasNick
  • 20 Answers
SOURCE: Color printing
Clogged nozzles the color cartridge needs cleaning with some cartridge flush or some other kind of solution and running a few good cleaning cycles, failing that use it more often to keep the cartridge from drying and causing the ink to stop flowing from the jets.
Posted on Dec 31, 2007
SOURCE: Lexmark P4350 All-in-One--Ink printout problem
It may sound stupid but try cleaning the steel rod that the cartridge runner runs along, with a little luck this may help the situation I know it has for others. It did not help me though. I have a Lexmart P for POXY 4350 that has had little use, but I have just tried to re-fill the black cartridge and kept getting iether the1203 or 1103 error code. I tried everything bar a complete strip down and it still does not work so I went and bought new cartidges and the problem has not gone away I am therefore stuck with £24's worth of rejected cartridges and a visit to Tesco for a new Epson.
Posted on Mar 02, 2008
worldvet
  • 859 Answers
SOURCE: phote prints out faded and in black and pink only
There are a number of single issues that can cause your problem in this case. The most common are listed below:
1.) Color cartridge expended.
2.) Print Paper selection incorrect.
From your statement above. I would suggest it is both item 1 and 2. Since, we are doing this assistance via chat mail, I can't come to your aid and witness myself what the results are and what your settings are for the paper type.
When you end up with a red hue over all over the print area the cause it usually a bad print head and selecting the wrong paper type.
To answer you question then, Yes, replace your color cartridge. But, first, try this method below to clean your color cartridge bubble jets.
When you go to print a job, always go into print setup or printer properties and choose the paper type as closely as you can to match the paper you are using.
The print head manual cleaning is listed below, it is from Lexmark. Below that is a process to clean blurry and bad print results. Although this is not specifically the case in your problem. The process to achieve resolution will also correct any problem your machine may be having. Remember, I do believe you need a new color cartridge. You will know with certainty however when you clean the cartridge head. If you do not see, cyan, magenta and yellow lines upon cleaning, at all, ever, then those inks are depleted. Replace your ink cartridge and then do these steps below the head cleaning.
Also, when ever you change a black or color cartridge you will want to run a print head alignment test and adjustment. There is enough of a difference in cartridges that this is quite necessary.
Please do not hesitate to give me as much feedback as possible on any issues and results you discover. You can use the comment text area below to respond to these instructions and give me the results of your tests and procedures.
Regards, Worldvet
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
To Resolve Print Quality Issues (below is for blurry lines, it will resolve many other issues too, so proceed after replacing your color ink cartridge if upon cleaning you see no ink coming out and the cartridge feels very light and makes little to no sound when you shake the cartridge.)
Overview This article outlines various techniques for resolving a blurry print issue. Cleaning the print cartridge nozzles is necessary when:
  • Characters are not printing completely.
  • White dashes appear in graphics or printed text.
  • Print is smudged or too dark.
  • Vertical, straight lines are not smooth.
  • Colors on print jobs are faded, or they differ from the colors on the screen.
Clean the Print Cartridge Nozzles using the Computer
    1. Load plain paper.
    2. Open the Lexmark Solution Center (go to Start, Programs, Lexmark XXXX Series, Lexmark Solution Center).
    3. From the Maintenance tab, click Clean to fix horizontal streaks.
    4. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
    5. Print the document again to verify that print quality has improved.
    6. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Clean and Wick the Cartridge
  1. Try cleaning and wicking the cartridge to help improve the print quality. See this article for directions.
  2. When this step is complete, try to run the clean print nozzles (CPN) operation again.
Auto Alignment · Align the print cartridges
Align the print cartridges after installing them to improve print quality. To do this:
    2. Open the Lexmark Solution Center.
    3. From the Maintenance tab, click Align to fix blurry edges.
    4. Click Print. NOTE: Discard the page after it prints.
User the Quality Settings in Print Properties
Print Properties is the software that controls the printing function when the All-In-One is connected to a computer. You can change the settings in Print Properties based on the type of project you want to create. Do the following:
  1. With a document open, click File, Print.
  2. In the Print dialog, click the Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears.
    Click here for an enlarged view.
  3. Try changing the following settings to see if your print quality improves:
    Quality/Copies
    Quality/Speed
    Multiple Copies·Specify how the All-In-One should print several copies of a single print job: collated or uncollated.
    Print Color images in Black and White·Select this to print color images in black and white.
    Paper Setup
    Paper Type·Select the type of paper you are using, or allow the printer sensor to select the paper type for you.
    Paper Size·Select the size of the paper you are using, and specify whether or not you want to print borderless.
    Orientation·Specify how you want the document oriented on the printed page - portrait or landscape.
    Print Layout
    Layout·Select the print layout you require.
    Duplexing·Select this option when you want to print on both sides of the paper.
Save Settings
From the Save Settings menu, you can name and save the current Print Properties settings for future use. You can save up to five custom settings
I Want To
The I Want To menu appears when you open Print Properties. It contains a variety of task wizards·printing a banner, printing a poster, printing a photograph, printing an envelope, printing on both sides of the paper·to help you select the correct print settings for a project.
Check the Media
If the print is still blurry, try printing the same image on a different media brand/type: plain paper designed for use with inkjet printerscard stockgreeting cards, index cards, postcards, or photo cardscoated paperphoto or glossy papertransparenciesiron-on transfersbanner paper
Use the Lexmark Photo Editor
Try printing a higher quality image, or print an image from a different source.
Posted on Dec 20, 2008
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: When I print pictures, they
    Try to the clean the nozzles of your color cartridge. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles with the Lexmark X7350. If problem continues, try to insert a different known working cartridge to deternine if your color cartridge is faulty.
    Posted on Mar 09, 2011
    Color Laser Printer Pink Tint
    have you tried cleaning the charging wire and the transfer belt
    Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
    Color streaks after gradation
    sounds like you need a new magenta drum
    Jan 14, 2014 | Canon imageRUNNER C3200 Copier
    Canon MP980 prints horizontal pink lines across
    try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
    Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
    Gives pink shadow on printing card paper 12 * 18
    One of 2 things, Replace the transfer cleaning blade. You may be able to clean it and get rid og the problem. The second thing to try is to replace the magenta drum, but thats less likely since you say it goes away in 3-4 pages.I suspect the transfer blade.
    Dec 23, 2008 | Xerox DocuColor 3535 Copier
    Hp psc 1510 prints reddish-pink color
    the photo come out pink and i buy yesterday can you help me hp 1510
    Oct 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
    Infoprint 1332
    in valid cartridge refill
    Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
    Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
    Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
    Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
    I have a hp officejet pro L7680 all-in-one printer.2007. I got new ink hp 88 combo pack & hp88xl black, but everything prints in pink color where the color part should be what ever the color is on the...
    Go into the control panel in windows, select printer and select the properties for your printer.
    Push the printing preferences button
    Select services
    Select service this device.
    Press the device service tab.
    Run all three tests.
    Alignmet, Clean and print a test page.
    Jun 28, 2008 | HP Office Equipment & Supplies
    My HP Laser Jet (color) 1600 is printing color on pages with no color!!
    the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
    Jun 04, 2008 | HP LaserJet 1600 Printer
    Colors
    Did you run a quality test print by pressing ink etc...?
    It might be that you have no magenta anymore.
    If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
    a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
    Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
    Lexmark C544dn Laser Printer Logo
    165 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
