How can I play a .wav file,.au file in a JDK 1.1.x applet?
Dear Sir,
I have some doubt, please help me in this regard. How can I play a .wav file,.au file in a JDK 1.1.x applet? I need some source code.
waiting for your reply
Abhi
    Genius:
  • 2,785 Answers
Plz try with vlc media player
Posted on Jan 12, 2009
Im trying to convert a QCP file to an MP3 file. I have a conversion program but it seems to be damaging the file, not full play time of the song/file and bad quality. how can I make this work?
Rename the file to .WAV (change the .QCP extension to .WAV) then you can either play the WAV file itself OR convert the WAV file (for free) with CDex.
Mar 02, 2011 | Computers & Internet
Windows Media Player can't play the file.
Check that the file being played has one of these file extensions. If not, then the file isn't played by windows media player.
Extensions: asf, .asx, .avi, .wav, .wma, .wax, .wm, .wmv, .wvx, .ra, .ram, .rm, .rmm, .mpg, .mpeg,
.m1v, .mp2, .mpa, .mpe, .aif, .aifc, .aiff, .au, .snd, .ivf, .mov.
Nov 30, 2010 | Computers & Internet
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Fatal error during installation
First u must make sure to close and exit all the applications that are using the resource of JDK.
Method 1: disable the auto load of JDK on machine start up from System Configuration Utility. Then reboot and try to uninstall again from the Add or Remove Programs.
Method 2: reinstall JDK and immediately uninstall it after the installation done. Or maybe u will found the uninstall function during the JDK setup.
Method 3: can try to use the cleaner software like CCleaner to uninstall the JDK application.
YBC (/\)
Jul 30, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
How to use window.h in c++
use windows.h header file and play the .wav file using PlaySound function as  e.g: PlaySound("C:\\SOUNDS\\BELLS.WAV", NULL, SND_ASYNC);
Thanks!
Apr 01, 2009 | Microsoft Computers & Internet
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Dec 23, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Mp3 to wav tones?
well fist confirm if u phone support .wav format..download mp3 to wav convertor from the internet..but i suggest u to play mp3 files..because in (.wav) format sound quality is not so good
Nov 27, 2008 | Nokia 6600
Open Questions:
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
