SOURCE: Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
