My maytag washer keep showing erro code f9E2 the drain pump is 60 Hz I have 50 Hz. Can that be the problem
5 Suggested Answers
  • 63 Answers
SOURCE: MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Posted on Nov 12, 2008
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Posted on Jun 05, 2009
  • 1382 Answers
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Posted on Apr 01, 2010
oldTech2332
  • 2341 Answers
SOURCE: He2 plus front load washer
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Posted on Aug 05, 2011
How to convert 50 hz waterpump to 60 hz??
you cant but difference between 50/60 hertz should not stop in running does the rest of machine work ok does it wash spin if so I would be lokking for wires of jammed pump ect
Mar 08, 2014 | Samsung Washing Machines
My kenmore elite quiet pak 4 washer is not draining . we cleanened the drain ane replaced the pump but ii stlll vontinues to show erroe code f21 and is not draining. what else could be the problem?
It can be due to the fact that there is no output to the drain when the program comes to the drain cycle, check the voltage to the drain before the drain pump can be confirmed to be faulty.
This can also be due to the program controller unit or a faulty connection in the harness to the drain pump
Aug 22, 2013 | Kenmore Elite 45986 Front Load Washer
The voltage in my country is 230volts 50HZ I have a 120/240 volts maytag dryer what can i do to get it working
Normally the 240 volts rating is nominal and the device will run at 230 volts. The question is will the dryer run at 50 HZ? Check on the electrical rating tag on the machine. It may work. The motor may just spin at 50/60, 5/6 of the 60 HZ speed.
Gary
Aug 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I cleaned the strainer, checked all the hoses, but still got the F-21. Checked the pump no objects inside. Still got the F-21. Checked the pump again and found the impeller does not spin freely. Is this...
I have the same problem: new drain pump, impeller needs to be "kicked" to start reciprocating (which, of course, is not possible once installed). Drain pump is listed as 50 Hz (UK), though I am in US (60 Hz) - could that make any difference?
Apr 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
50 hertz microwave to send in Philippines which frequency is50-60
u.s. is all 60 hz. not sure in the phillipines,the only issue is it will cook slower due to the lower input frequency, it shows no electronic control board in the diagram, sometimes a different freq. can throw electronics off i.e. the clock would run slower and not keep accurate time on 50 hz. as it would on 60hz.
Oct 11, 2009 | Sharp R-510HW Microwave Oven
What is the wiring sequence for itt marlow sd 100 bath pump in uk (colour code of wiring?)
universal wiring on the Gemini pump since it works 50 Hz or 60 Hz
black=hot
white=common
green-ground
Jul 10, 2009 | Home
Maytag washer gives code "nd" and stops! What is the problem??
"nd" is code for "difficult draining" installed a new water pump $60, problem solved.
May 11, 2009 | Maytag MAH8700A Front Load Washer
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Washing Machines Logo
397 people viewed this question
Top Washing Machines Experts
