Question about Kitchen Ranges
Install eoc in frigidaire ples389ech - Kitchen Ranges
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: instructions for frigidaire oven
an f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
How do you change a dual element control on a frigidaire Mod#PLES389ECH. I do not know how to take off the cover under the knob. My oven knobs is on the front of the oven not the back as indicated in...
Good Afternoon Friend,
I understand you are trying to change the dual element control on your Frigidaire range, model# PLES389ECH. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the dual element control with ease. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FEF366DC Electric Kitchen Range
Quatre par convection Erreur auto Frigidaire Nettoyant f 3 et f 1
F3 -The oven temperature sensor is open
Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
F1- EOC (Electronic Oven Control) failure
Replace EOC (Electronic Oven Control)
Thank You
Sep 03, 2010 | Frigidaire Ovens
F6 ERROR CODE ON MY FRIGIDAIRE STOVE.
dagadier
We may be able to repair your EOC, what are the symptoms?
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
I have a f30 error can i fix this myself? I have unpluged the stove and i need to know where to look for this
OK - here's a little tip that might save you a bundle of cash:
The Frigidaire glasstop slide-in Range model # PLES389ECH has a habit of triggering a F30 error, which according to the NEW table of error codes (http://www.applianceaid.com/faultcodes3.html), implies an issue with either the Electronic Oven Control (EOC) panel (located beneath the Control Panel Assembly), or the temperature probe itself (located within the main oven cavity, back wall, upper-left corner). However, a quick glance at page 12 of the Factory Parts Catalog's wiring diagram (http://www.youserguide.com/wiki/Frigidaire_PLES389ECH or http://www.serviexcell.com.mx/manuales/PLES389ECH.pdf) shows two thermal breakers wired into the circuit as well.
To check the probe, disconnect power and either pull the probe from the cavity of the oven (two screws, and a disconnect plug) and measure resistance across the probe, or take the Control Panel Assembly off the front (remove 4 cooktop control knobs and 4 teflon mounting nuts) and measure resistance at the EOC P5 quick-disconnect plug (violet wires - see wiring diagram)...it should read approx. 1091 Ohms at room temperature per ApplianceAid's table. If you measured at the probe, an open (infinite resistance) or short (zero resistance) indicates a bad probe. Replace for about $40.00 (per http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160618).
If you get an open or short by measuring at the P5 plug, the issue is either the probe OR the thermal breakers. Also called a Thermal Cutout Switch (item #141 on p.8 of your parts catalog), one of these buggers is located near the electronic control module for the right rear stovetop burner (#54A, follow the violet wires from EOC to locate it) - since you already have the Control Panel Assembly pulled, reach over and push the button on the breaker to reset it. This may have just solved your error code! For FREE!! If it doesn't reset, you may have to replace the breaker itself (around $16.00).
However, if you measured at the plug and get the appropriate resistance for the entire circuit it's likely that your breakers, probe and wiring harness (always check for disconnected wiring) are fine, and that the problem lies with the EOC itself. This pricey gizmo runs a little over $200. My sympathies.
Good luck! Feel free to mail me any contributions should you save yourself a $350+ service call. :)
Dec 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Instructions for frigidaire oven
Dec 16, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Thanks for the question. remove the back panel. first cut the power to the stove .remove the clips that hold the board, install new one. install the wiring on the new one. thanks the appliance doc.
Sep 27, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
