Question about Nokia N72 Cellular Phone
Cam not working properly
When i open the slide in n72 to take camera it takes time to diaplay.when i close the slide ,sometime after the camera displays .i dont know whether the slide was problem or any virus.
    Master:
  • 383 Answers
First backup the phone data and then perform this format ( Data gets Deleted) *#7370# .... default code is 12345 .. After this restore the backup made ... this shud resolve the problem
Posted on Jan 12, 2009
The freezer door does not close properly, or opens by itself as if one of the drawers is pushing it open. The drawers are all closed correclty and there are no obstructions or foreign objects preventing...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Mar 23, 2011 | Refrigerators
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Sometimes won't open and can't import my pictures
The lens won't open or the comp. won't read the cam?
If it is on the cam:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Does the blue screen apear on the cam or the computer?
If on the cam:
Reset the cam: Take the batt out for longer than 10 sec.
Exchange the SD card.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 11, 2009 | Kodak Easyshare 1725043 M893Is Digital...
When cam is on? cell says plz open slide
The switch that detects when the slid is open isnt making contact, open it (remove the battery cover) and clen the 2 brass contacts, if that doesnt work, replace the back cover.
Oct 27, 2009 | Nokia N72 Cellular Phone
Bosch larder fridge door pops open
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Oct 19, 2009 | Refrigerators
Camera on standby open lens cover
take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Jun 23, 2009 | Nokia N72 Cellular Phone
Cam not displaying
Format Ur Mobile as *#7370#
Put password as 12345
If Not Done Update ur Mobile Software.
Dec 24, 2008 | Nokia N72 Cellular Phone
Flashing code
my nokia n72 camera is not working, when i open the slide it says unexpected error occured. power off the device and restart.
Nov 02, 2008 | Nokia N72 Cellular Phone
Lens only comes half way out
I had a problem that may be related to yours. From time to time, whenever I opened the cover, the lens wouldn't work properly. It would make a grinding noise and then when I took pictures they would all come out out of focus. After much fiddling about, I eventually discovered that if I set ALL RESET to FALSE on the SETUP menu, it returned to normal. Possibly this could fix your problem. Otherwise maybe its a battery problem. My camera sometimes refuses to take pictures when the battery is low.
Sep 24, 2007 | Olympus Camedia C-350 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Nokia N72 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
