Question about Frigidaire FWSB7800DS Top Load Washer
Frigidare FWSB7800DS0 super capacity plus, commerical heavy duty leaking
Has a slow leak
3 Suggested Answers
  • 1531 Answers
SOURCE: I have a Frigidaire heavy duty 8 cycle super
there is something blocking the pump.you will need to remove the two screws at the bottom of the front panel ten use a flat tip screwdriver to push the tabs in on the front to lift the lid. once you remove the front panel you will be able to see the drain pump.
if you have a wet dry shop vac then you can use it to attach to the end of the drain hose.and remove the water once the water is removed take off the hoses to the pump and check for obstructions.
make sure to check the hose that come from the bottom of the tub to the pump. once you have cleared and obstructions you can put the unit in a drain mode and check the impellar wheel if it still does not work then you may have a faulty lid switch.
Posted on Feb 10, 2011
kevin_getz
  • 1031 Answers
SOURCE: whirlpool heavy duty super capacity plus LSR 7233 EZO
Most likely, the legs on the machine aren't level, causing it to move during operation.
Posted on Jun 13, 2012
I have a whirlpool ultimate heavy duty super capacity plus an over loaded it an the cold water hose is leaking. Is that normal?
Overload is too many clothes. So that is a choice to be made, and not normal for the machine. It isn't made for overload and
does not like that situation. Cold water hose leaking is not normal.
How old is it? Most plumbers appliance installers recommend changing the hot and cold hose every five years. It's cheap insurance against a "flood" if one or both break.
Feb 28, 2015 | Whirlpool Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine leaks
Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool heavy duty super capacity plus
What is the model number of your washer if it is a Duet then First you need to unplug the washer and then remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom).The top cover comes of just as easy the 3 Phillips screws are on the top back side of the machine.....If its not a Duet please give me the model number and I'll see what I can find for ya…. Please give me feed back
cbinny1
Oct 19, 2008 | Washing Machines
Frigidaire FWSB7800DS Top Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
