Question about Toshiba e310 Pocket PC
Looking for software for Toshiba e310 Pocket PC
I was given a Toshiba e310 pocket PC by a family friend. Once I replaced the old battery it runs perfectly. However I don't have any of the original software that it came with. Therefore I can't sync it with my PC. I also have a Palm Z22 and have it's software installed. This device works perfectly and reinforces the fact that without the software for my e310 I am unable to take full advantage of all it's functions. Does anyone know where I can finde the software for this PDA? I am also curious if I can upgrade the version of Windows that my e310 is running. My current OS is: Microsoft Pocket PC Version 3.0.11171 (Build 11178) Does anyone know if this model is able to run a newer version of Windows? And if so, does anyone know where I can find it? Is it a free upgrade or do I have to pay for any OS upgrades?
  • 689 Answers
You need driver for the device itself as linked below;
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=210707&moid=429792&rpn=PD350U&BV_SessionID=@@@@0428634131.1202426047@@@@&BV_EngineID=cccjadedfdfdldgcgfkceghdgngdgnn.0&ct=DL&all_docs=false
After that download and install Microsoft Active Sync from microsoft as linked below;
http://www.microsoft.com/windowsmobile/activesync/default.mspx
I hope it will fix the problem
Good Luck
Posted on Feb 07, 2008
My son bought a Toshiba pocket PC e740/e310. No software came with it and we know nothing about pocket pc's. Where can we get software to download to get him started?
Thanks Shell
Posted on Nov 09, 2008
SOURCE:
Pocketmac toshiba e310
Check out mark-space software, it worked well for me
Feb 08, 2008 | Toshiba e310 Pocket PC
My Toshiba e310 turns on by itself
It could be a piece of software that you have recently installed "activating" your PDA. I had this problem after installing a program that, amongst other things, monitored battery life. Once i uninstalled it it was fine so whether that was just a big coincidence i dont know.
Sep 15, 2005 | Toshiba e310 Pocket PC
My PC not turn on
Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
Sep 08, 2005 | Toshiba e310 Pocket PC
My PC not turn on
The Toshiba Pocket PC e310 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (19 of 104).
Windows CE Program's
On the new Toshiba e310, e570 and e740 Pocket PCs, Microsoft's new operation system Pocket PC 2002 is installed. The question whether Windows CE programs run under Pocket PC 2002 has no definite answer. Most Windows CE Program will run under Pocket PC 2002. Pocket PC 2002 is an improved version of Windows CE, or rather, the next generation of Microsoft PDA operating systems. Some parts of the internal architecture of the operating system, like the e-Mail system, are of a complete new design and in fact, quite different. So if you run older Windows CE programs using "old and possibly, changed parts of Window CE system", it is quite possible that the Windows CE program will not run or will not operate correctly. Tip: To avoid problems or data loss, we suggest using Pocket PC 2002 programs only. Please note: Pocket PC 2002 is only available for Intel "Strong ARM" processors. This is different to Windows CE, where several CPU's types were supported. Only Windows CE Programs for Intel Strong ARM" processors may run an Pocket PC 2002.
Sep 07, 2005 | Toshiba e330 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e310 Pocket PC Logo
373 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
