Question about Electrolux 23 in. ESL624 Built-in Dishwasher
Hi my dishwasher Electoluc ESL624 will start the cycle but no water comes through and then it stops
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: ESL624 dishwasher. On any cycle
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 28, 2011
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
5 year old dishwasher.Press START button,dishwashing cycle kicks in for a few seconds then stops.A few seconds wait and it starts again, and on and on.It finally works its way to the full cycle.
The dishwasher is taking too long to fill with water...
Here is a tip that will help you to find out whywater will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 24, 2011 | Whirlpool Dishwashers
The detergent capsules doe snot get used during the cycle. It just stays in the holder and gets damp. any suggestions?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Electrolux 23 in. ESL624 Built-in...
My dishwasher is having any water to it
Please brief us the issue so that we can assist you better.
Waiting for your response.
Thank You
May 14, 2010 | Electrolux 23 in. ESL624 Built-in...
Washing up liquid was put in the dishwasher...how do I get rid of it?
cold water and keep draining it take about ten times it should come out of it
Dec 06, 2009 | Electrolux 23 in. ESL624 Built-in...
What would make the dishwasher trip the breaker at different cycles
It could be a few different things. If the breaker is rated close to the amp draw of the unit (e.g. 10 amp breaker and the washer is pulling 9.5 A) , or if there are multiple devices that particular breaker services that is causing a higher amp draw.
Slim chance the motor in the washer could have a bad start capacitor, causing it to draw more amperage when the pump or motor comes on.
Please let me know if this helped.
Matt
Sep 12, 2009 | Electrolux 23 in. ESL624 Built-in...
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
No water coming into machine !!!
take the main supply hose off remove the panel that covers the valve yoy should be able to see a red pipe with a white stopper in it. remove this and see if any water comes out if so rebuild the machine and see if that works. hope this helps
Feb 09, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux 23 in. ESL624 Built-in Dishwasher Logo
32 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
